* clock/ckinit.c, console/sci.c, console/sci.h, include/bsp.h,
misc/interr.c, startup/bspstart.c, timer/timer.c: Convert to using
c99 fixed size types.
spurious/Makefile.am, startup/Makefile.am, timer/Makefile.am,
wrapup/Makefile.am.
Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, spurious/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am:
Remove.
* timer/timer.c: Remove efi68k and efi332 references as they are no
longer in the tree.
* spurious/Makefile.am: Cosmetics.
* spurious/Makefile.am: Remove all-local: $(ARCH).
* clock/ckinit.c, console/console.c, include/bsp.h, misc/interr.c,
spurious/spinit.c, startup/bspclean.c, startup/bspstart.c,
timer/timer.c: URL for license changed.
spurious/Makefile.am: Reflect having moved automake.
* spurious/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* spurious/Makefile.am: Use .$(OBJEXT) instead of .o.
* spurious/Makefile.am: Remove AUTOMAKE_OPTIONS.
wrapup/Makefile.am: Modified to include compile.am.
* startup/bspstart.c: Removed include of <libcsupport.h>
* .cvsignore, ChangeLog Makefile.am, README, bsp_specs,
clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in,
console/.cvsignore, console/Makefile.am, console/console.c,
include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c,
spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c,
start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore,
startup/Makefile.am, startup/bspclean.c, startup/bspstart.c,
startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM,
timer/.cvsignore, timer/Makefile.am, timer/timer.c, times,
wrapup/.cvsignore, wrapup/Makefile.am: Initial files.
