* | 2011-07-13 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2011-07-13 | 1 | -2/+1 |
| | | | | | | | | PR 1824/cpukit * misc/interr.c, spurious/spinit.c: Return exit/shutdown status back to boot_card(). boot_card() propagates this to bsp_cleanup() and returns it to the assembly that started the application. bsp_cleanup() prototype changed. | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-06 | 1 | -1/+1 |
* | 2008-06-02 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-06-02 | 1 | -3/+3 |
| | | | | | * misc/interr.c: Convention calls for leading underscore on private RTEMS variables. | ||||
* | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-31 | 1 | -1/+1 |
| | | | | | | * clock/ckinit.c, console/sci.c, console/sci.h, include/bsp.h, misc/interr.c, startup/bspstart.c, timer/timer.c: Convert to using c99 fixed size types. | ||||
| | | | | | | * clock/ckinit.c, console/console.c, include/bsp.h, misc/interr.c, spurious/spinit.c, startup/bspclean.c, startup/bspstart.c, timer/timer.c: URL for license changed. | ||||
* | 2000-05-25 Matt Cross <profesor@gweep.net> | Joel Sherrill | 2001-05-25 | 3 | -0/+130 |
* New MRM332 BSP for the Mini RoboMind board based on the 68332 microcontroller designed and build by Mark Castelluccio. For details on the MRM see http://www.robominds.com. * .cvsignore, ChangeLog Makefile.am, README, bsp_specs, clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in, console/.cvsignore, console/Makefile.am, console/console.c, include/.cvsignore, include/Makefile.am, include/bsp.h, include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c, spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c, start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore, startup/Makefile.am, startup/bspclean.c, startup/bspstart.c, startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM, timer/.cvsignore, timer/Makefile.am, timer/timer.c, times, wrapup/.cvsignore, wrapup/Makefile.am: Initial files. |
