line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Changed console driver to use interrupts instead of polling.
Change to avoid overwriting CPU32Bug interrupt vector when setting up the Sci interrupt handler.
Fixed type for boolean flag in bsp.h.
Changed mrm332.h to use 25Mhz clock.
Fixes to mrm332.cfg to use correct mcpu32 value for RTEMS_CPU_MODEL instead of m68332 which is no longer supported.
Added -mcpu=cpu32 to compiler options.
Removed broken ROM linker script and replaced broken RAM linker script with working ROM linker script.
Removed no longer required file except_vect_332_ROM.S.
Enabled 0xbeefbeef magic string in start.S to allow MRM version of CPU32Bug to auto run RTEMS.
Removed old code from start.S
Changed compiler optimization flag to optimize for size.
* include/bsp.h, include/mrm332.h, spurious/spinit.c:
* console/sci.c, include/mrm332.h, startup/linkcmds,
startup/linkcmds_ROM: Various updates to make this run properly
from ROM.
* console/sci.c, console/sci.h,
console/console.c: Added new SCI driver.
* start/start.c: Removed file.
* start/start.S: New file, the asm portion of the updated start code.
* start/configure.am: Added start.S, removed start.c
* startup/start_c.c: New file, the C portion of the updated start code. Contains most of the code that was in the old start.c.
* startup/configure.am: Added start_c.c to C_FILES.
* include/bsp.h: Added include <rtems/bspIo.h>
* .cvsignore, ChangeLog Makefile.am, README, bsp_specs,
clock/.cvsignore, clock/Makefile.am, clock/ckinit.c, configure.in,
console/.cvsignore, console/Makefile.am, console/console.c,
include/mrm332.h, misc/dotests, misc/gdbinit68, misc/interr.c,
spurious/.cvsignore, spurious/Makefile.am, spurious/spinit.c,
start/.cvsignore, start/Makefile.am, start/start.c, startup/.cvsignore,
startup/Makefile.am, startup/bspclean.c, startup/bspstart.c,
startup/except_vect_332_ROM.S, startup/linkcmds, startup/linkcmds_ROM,
timer/.cvsignore, timer/Makefile.am, timer/timer.c, times,
wrapup/.cvsignore, wrapup/Makefile.am: Initial files.
problems that prevented the 19990302 snapshot from running on
the efi332.
I'm happy to report that rtems-19990302 is running on the efi332
board. I have enclosed a few minor patches below to the efi332 bsp. All
patches are within that library but one. make/custom/efi332.cfg has a
patch to select the right CPU_CFLAGS (at one time -m68332 was a
problem... -mcpu32 or -m68332 work fine now).
commit them.
