PR 1824/cpukit
* misc/interr.c, spurious/spinit.c: Return exit/shutdown status back to
boot_card(). boot_card() propagates this to bsp_cleanup() and returns
it to the assembly that started the application. bsp_cleanup()
prototype changed.
PR 1772/bsps
* console/sci.c: Use same default baud rate as monitor.
* timer/timer.c: Include <bsp.h> before <rtems/btimer.h>.
* include/bsp.h, include/mrm332.h, spurious/spinit.c:
* timer/timer.c: Include <rtems/btimer.h>.
* spurious/spinit.c: Add include of bootcard.h to fix warning.
* startup/bsppredriverhook.c: Remove warnings.
* make/custom/mrm332.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/mrm332.cfg: New (relocated from /make/custom).
* console/sci.c: Reflect termios_baud_to_number having been
renamed to rtems_termios_baud_to_number.
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* include/bsp.h: Defined as a small memory target. It cannot build
one of the sample programs any more.
* start/start.S: Update for boot_card command line change.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* timer/timer.c: Eliminate uses of old benchmark timer names.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Remove noinst_PROGRAMS (Unused).
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* Makefile.am: BSP specific bsp_cleanup() is a dupe of a shared one.
* startup/bspclean.c: Removed.
* include/bsp.h: Remove unnecessary boilerplate comments.
* Makefile.am, startup/linkcmds, startup/linkcmds_ROM: Use top level
shared bsp_get_work_area() implementation.
* startup/bspstart.c: Removed.
* Makefile.am, configure.ac, clock/ckinit.c, startup/linkcmds,
startup/linkcmds_ROM: Add use of bsp_get_work_area() in its own file
and rely on BSP Framework to perform more initialization. Remove
unnecessary includes of rtems/libio.h and rtems/libcsupport.h.
* startup/bsppredriverhook.c: New file.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* misc/interr.c: Convert to "bool".
* clock/ckinit.c: The Shared Memory Driver no longer requires the
special IOCTL in Clock_control. This was a hack which has existed
since before the Classic API Timer Manager was implemented. All
implementations of and references to Clock_control were removed.
* timer/timer.c: Convert to "bool".
* timer/timer.c: Eliminate empty function from every benchmark timer
driver. Fix spelling.
* timer/timer.c: Rename timer driver methods to follow RTEMS
programming conventions.
* console/sci.c, startup/bspstart.c, startup/start_c.c,
timer/timer.c: Add missing prototypes.
* misc/interr.c: Convention calls for leading underscore on private
RTEMS variables.
* Makefile.am: Rework to avoid .rel files.
* console/console.c, startup/bspstart.c: Refactored and renamed
initialization routines to rtems_initialize_data_structures,
rtems_initialize_before_drivers, rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* startup/linkcmds, startup/linkcmds_ROM: Add wildcard to
gcc_except_table section so programs compiled with gcc 4.3.x can
link.
* clock/ckinit.c, include/bsp.h, startup/bspstart.c: Eliminate copies
of the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field
from CPU Table to Configuration Table. Eliminate CPU Table from all
ports. Delete references to CPU Table in all forms.
* startup/bspstart.c: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* startup/bspstart.c: Eliminate the interrupt_vector_table field in the
m68k CPU Table since it is never read.
* startup/linkcmds: Handle .data.* sections
* bsp_specs: Remove qrtems_debug.
* include/bsp.h: Remove redundant prototypes.
