Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
Conflicts:
for details.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* startup/cfinit.c:
* timer/timer.c: Include <rtems/btimer.h>.
* network/network.c: Fix warning.
* console/console.c: Add BSP_poll_char.
* console/console.c: Fix broken comment formatting.
* startup/cfinit.c: Remove init_vbr (Unused).
* make/custom/mcf5329.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/mcf5329.cfg: New (relocated from /make/custom).
* console/console.c: Reflect termios_baud_to_number having been
renamed to rtems_termios_baud_to_number.
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* startup/init5329.c: Update for boot_card command line change.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared stub coverhd.h
* include/coverhd.h: Removed.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* clock/clock.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
PR 1322/bsps
* include/bspopts.h.in: Remove.
PR 1322/bsps
* configure.ac, include/bspopts.h.in: Make letting boot_card() handle
work area allocation mandatory. Rename
RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to BSP_BOOTCARD_OPTIONS.
* Makefile.am, configure.ac, include/bspopts.h.in: Use standardized
bsp_cleanup() which can optionally print a message, poll for user to
press key, and call bsp_reset(). Using this eliminates the various
bsp_cleanup() implementations which had their own implementation and
variety of string constants.
* startup/bspclean.c: Removed.
* include/bsp.h: Remove unnecessary boilerplate comments.
* Makefile.am, startup/linkcmds, startup/linkcmdsflash: Use top level
shared bsp_get_work_area() implementation.
