* Makefile.am, configure.ac, startup/bspstart.c: Add use of
bsp_get_work_area() in its own file and rely on BSP Framework to
perform more initialization. Remove unnecessary includes of
rtems/libio.h and rtems/libcsupport.h.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* timer/timer.c: Convert to "bool".
* timer/timer.c: Eliminate empty function from every benchmark timer
driver. Fix spelling.
* timer/timer.c: Rename timer driver methods to follow RTEMS
programming conventions.
* clock/clock.c, startup/init5329.c: Add missing prototypes.
* Makefile.am, README, include/coverhd.h, network/network.c,
startup/bspstart.c, startup/cfinit.c, startup/linkcmdsflash: Add
cache support for 5329. Fix bug in network driver. Enable the cache
in copyback and write-through so we can assume that in BSP.
* .cvsignore: New file.
* startup/linkcmds: Use wildcard on .data section.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac, gdb-init,
preinstall.am, clock/clock.c, console/console.c, include/bsp.h,
include/bspopts.h.in, include/coverhd.h, include/tm27.h,
network/network.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/cfinit.c, startup/init5329.c,
startup/linkcmds, startup/linkcmdsflash, timer/timer.c: New files.
