Update #3285.
Remove old ISR parameter since is not used by the clock driver shell.
Make an implementation optional.
Update #3139.
Make Clock_driver_support_shutdown_hardware() optional. This avoids
the atexit() support on memory constrained targets.
Update #2502.
Update #2271.
* clock/clock.c: include "../../../shared/clockdrv_shell.h".
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac, gdb-init,
preinstall.am, clock/clock.c, console/console.c, include/bsp.h,
include/bspopts.h.in, include/coverhd.h, include/tm27.h,
network/network.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/cfinit.c, startup/init5329.c,
startup/linkcmds, startup/linkcmdsflash, timer/timer.c: New files.
* mcf52235/README, mcf52235/gdb-init, mcf52235/clock/clock.c,
mcf52235/console/console.c, mcf52235/include/bsp.h,
mcf52235/include/coverhd.h, mcf52235/start/start.S,
mcf52235/startup/bspclean.c, mcf52235/startup/bspstart.c,
mcf52235/startup/linkcmds, mcf52235/timer/timer.c: Cleaned up
white space and code formmated to adhere to RTEMS standards. Fixed
a bug in the nano seconds since last tick support. Fixed a bug
with the location of the start stack (no longer within
.bss). Removed double definition of IPSBAR and some type defs
etc.. Added timing test overhead results.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs,
clock/clock.c, configure.ac, console/console.c, gdb-init,
include/bsp.h, include/bspopts.h.in, include/coverhd.h,
include/tm27.h, preinstall.am, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/cfinit.c, startup/init52235.c,
startup/linkcmds, timer/timer.c: New.
