path: root/c/src/lib/libbsp/m68k/mcf5235/startup/bsp_specs (unfollow)
2018-04-20bsps: Move startup files to bspsSebastian Huber1-10/+0
Adjust build support files to new directory layout. This patch is a part of the BSP source reorganization. Update #3285.
2018-01-25Remove make preinstallChris Johns1-0/+0
2017-12-20gen68340: Simplify bsp_specsJoel Sherrill1-5/+2
Updates #3520.
2008-12-042008-12-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-2/+2
* bsp_specs: Move -e start from *link to *startfile to avoid warning for undefined entry symbol when linking relocatables with binutils 2.19.
2007-04-122007-04-12 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius1-5/+2
* bsp_specs: Remove qrtems_debug.
2003-09-192003-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-8/+0
* bsp_specs: Remove *lib:.
2003-08-062003-08-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-3/+0
* bsp_specs: Remove -D__embedded__ -Asystem(embedded) from cpp. Remove cpp, old_cpp (now unused).
2002-08-212002-08-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-4/+4
2002-01-042001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
* bsp_specs: Replace -lrtemsall with -lrtemsbsp -lrtemscpu, replace -lrtemsall_g with -lrtemsbsp_g -lrtemscpu_g.
2000-01-12Eric Norum <eric@cls.usask.ca> submitted linker script and bsp_specsJoel Sherrill1-1/+5
for the gen68360 that let it work with ELF and C++ exceptions. This was used as the basis for changes to EVERY m68k bsp_specs and linkcmds. Before this modification is over, the layout of the starting stack, heap, and workspace will likely be modified for every m68k BSP. Then they will all be very similar.
1999-11-19Renaming all BSP specific startXXX directories to use the same name (start).Joel Sherrill1-2/+2
1998-07-01Initial submission of gen68340 BSP (should run on a 68349) fromJoel Sherrill1-2/+2
Geoffroy Montel <g_montel@yahoo.com>.
1998-06-27PC386 BSP enhancements from Aleksey Romanov (Quality QuorumJoel Sherrill1-1/+1
<qqi@world.std.com>). Unfortunately after merging these, the pc386 will not boot using grub for for. It still does not work using netboot for me. Here is his summary of changes: rtems/c/src/lib/libbsp/i386/pc386/Makefile.in Added support for new sub-directory rtems/c/src/lib/libbsp/i386/pc386/bsp_specs Made possible to build COFF image rtems/c/src/lib/libbsp/i386/pc386/console/console.c Added support for serial consoles, selectable by patching binary image, added __assert(), use _IBMPC_inch_sleep() instaed of _IMBPC_inch() rtems/c/src/lib/libbsp/i386/pc386/console/inch.c Added _IMBPC_inch_sleep() rtems/c/src/lib/libbsp/i386/pc386/console/outch.c Oops - just formatting rtems/c/src/lib/libbsp/i386/pc386/include/Makefile.in Added support for new files rtems/c/src/lib/libbsp/i386/pc386/include/bsp.h Added support for new features rtems/c/src/lib/libbsp/i386/pc386/include/pc386uart.h New file: definitions for serial ports rtems/c/src/lib/libbsp/i386/pc386/include/pcibios.h New file: definitions for PCI BIOS rtems/c/src/lib/libbsp/i386/pc386/pc386dev/Makefile.in New file: makefile in new directory rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub-glue.c New file: i386-stub interface rtems/c/src/lib/libbsp/i386/pc386/pc386dev/i386-stub.c New file: i386-stub itself rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pc386uart.c New file: serial ports rtems/c/src/lib/libbsp/i386/pc386/pc386dev/pcibios.c New file: PCI BIOS support rtems/c/src/lib/libbsp/i386/pc386/start/start.s Commented out DEBUG_EARLY stuff, everything is working fine rtems/c/src/lib/libbsp/i386/pc386/start/start16.s Cleaned up rtems/c/src/lib/libbsp/i386/pc386/startup/bspstart.c Added call to console_resereve_resources rtems/c/src/lib/libbsp/i386/pc386/startup/exit.c Added support for serial console rtems/c/src/lib/libbsp/i386/pc386/startup/ldsegs.s Fixed typo in comments rtems/c/src/lib/libbsp/i386/pc386/tools/Makefile.in Changed to reflect cnages in code rtems/c/src/lib/libbsp/i386/pc386/tools/bin2boot.c Trivialized, problem - I do not know how to make patch remove obsolete files - there are a lot of them there rtems/c/src/lib/libbsp/i386/pc386/tools/binpatch.c New file: utility to do binary patches rtems/c/src/lib/libbsp/i386/pc386/wrapup/Makefile.in Added support for new directory rtems/make/custom/pc386.cfg Add COFF image building
1998-04-27Update from Pedro Romano <pmcnr@camoes.rnl.ist.utl.pt>.Joel Sherrill1-1/+1
1998-02-11Incorporated Ralf Corsepius' idea for new -q flags to properly supportJoel Sherrill1-2/+7
"gmake debug".
1997-12-20Moved -qnolinkcmds option so arguments passed on the command line areJoel Sherrill1-2/+2
interpreted at the right point per Eric Norum's discovery: The problem with the my previous `fix' for adding linker commands was with the ordering of the options to the linker. For example, to make a larger heap size, the application Makefile would CFLAGS_LD = -Wl,--defsym -Wl,HeapSize=0x40000 The command passed to the linker would be : m68k-rtems-ld .... -T xxx/linkcmds .... --defsym HeapSize=0x40000 ..... This doesn't work because the script in linkcmds inserts a default value for HeapSize if HeapSize is not defined by the time the linker looks at the linkcmds script. The solution seems to be to move the -T linkcmds%s in the bsp_specs file out of the link specfication and into the lib specification -- a little unorthodox, perhaps, but it seems to work!
1997-12-19Modified bsp_specs per Eric Norum's suggestion to handle -qnolinkcmdsJoel Sherrill1-1/+1
switch which lets the user specify a different linker script.
1997-12-01Inclusion of PC386 BSP submitted by Pedro Miguel Da Cruz Neto RomanoJoel Sherrill1-0/+0
<pmcnr@camoes.rnl.ist.utl.pt> and Jose Rufino <ruf@asterix.ist.utl.pt> of NavIST (http://pandora.ist.utl.pt/).
1997-10-08Modified to search RTEMS library before Newlib C library.Joel Sherrill1-1/+1
1997-08-28Switched to new style which does not require hackspecs.awk.Joel Sherrill1-29/+13
1997-01-28new file used by gcc 2.8.x -specs optionJoel Sherrill1-0/+34
