* startup/init5235.c:
* timer/timer.c: Include <rtems/btimer.h>.
* network/network.c: Fix warning.
* console/console.c: Add BSP_poll_char.
* startup/init5235.c: Remove warnings.
* startup/init5235.c: Add volatile to prevent newer gcc versions from
optimizing away.
* make/custom/mcf5235.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/mcf5235.cfg: New (relocated from /make/custom).
* console/console.c: Reflect termios_baud_to_number having been
renamed to rtems_termios_baud_to_number.
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* Makefile.am: Compile the shared bspinit.c.
* start/start.S: Update for boot_card command line change.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared stub coverhd.h
* include/coverhd.h: Removed.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* clock/clock.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* Makefile.am, configure.ac: Use standardized bsp_cleanup() which can
optionally print a message, poll for user to press key, and call
bsp_reset(). Using this eliminates the various bsp_cleanup()
implementations which had their own implementation and variety of
string constants.
* startup/bspclean.c: Removed.
* Makefile.am, startup/bspstart.c: Split out bspstart contents. Move
cache code to libcpu.
* startup/bspgetcpuclockspeed.c: New file.
* include/bsp.h: Remove unnecessary boilerplate comments.
* Makefile.am, startup/linkcmds, startup/linkcmdsflash,
startup/linkcmdsram: Use top level shared bsp_get_work_area()
implementation.
* Makefile.am, configure.ac, startup/bspstart.c, startup/linkcmds,
startup/linkcmdsflash, startup/linkcmdsram: Add use of
bsp_get_work_area() in its own file and rely on BSP Framework to
perform more initialization. Remove unnecessary includes of
rtems/libio.h and rtems/libcsupport.h.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* timer/timer.c: Convert to "bool".
* timer/timer.c: Eliminate empty function from every benchmark timer
driver. Fix spelling.
* timer/timer.c: Rename timer driver methods to follow RTEMS
programming conventions.
* startup/init5235.c: Add missing prototypes.
* startup/bspstart.c: Do not disable interrupts twice.
* Makefile.am: Add shared/m68kbspgetworkarea.c to sources.
* configure.ac: Add RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION.
* include/bsp.h: Add include bspopts.h.
* start/start.S: Formatting changes.
* startup/bspstart.c: Updated to use the shared BSP support.
* include/bsp.h: FEC unit numbers based on 0 not 1. Change the
interface name to fec0.
* console/console.c: Eliminate copies of switches to convert termios
Bxxx constants to xxx as an integer. Use the shared
termios_baud_to_number() routine to do the same conversion.
* Makefile.am: Rework to avoid .rel files.
* startup/bspstart.c: Refactored and renamed initialization routines to
rtems_initialize_data_structures, rtems_initialize_before_drivers,
rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* console/console.c: Remove all references to console_reserve_resources
and termios_reserve_resources.
* startup/linkcmds, startup/linkcmdsflash, startup/linkcmdsram: Add
wildcard to gcc_except_table section so programs compiled with gcc
4.3.x can link.
* gdb-init: Make the first hb temporary.
* network/network.c: Add support for reading the MAC address from
the FEC if set by the boot monitor. dBug does not do this unless
the network is used which is a shame.
* gdb-init: Add the show-exception.
* include/bsp.h, startup/bspstart.c: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
* startup/bspstart.c: Move interrupt_stack_size field from CPU Table to
Configuration Table. Eliminate CPU Table from all ports. Delete
references to CPU Table in all forms.
* Makefile.am, startup/bspstart.c: Moved most of the remaining CPU
Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* console/console.c: Set the baud rate for stdin to 19200 when
opening the console. This is the default rate for the dbug
monitor.
* gdb-init: New.
* startup/bspstart.c: Eliminate the interrupt_vector_table field in the
m68k CPU Table since it is never read.
* startup/linkcmds: Handle .data.* sections
