Do not return from rtems_initialize_start_multitasking() and call
rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and
a fatal code with the exit status.
Remove all bsp_cleanup() functions. The boot_card() is now a no return
function.
Use <bsp/bootcard.h> to get prototype for bsp_cleanup(). Fix
bsp_cleanup() definition if necessary.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
PR 1824/cpukit
* include/bsp.h, startup/bspclean.c: Return exit/shutdown status back
to boot_card(). boot_card() propagates this to bsp_cleanup() and
returns it to the assembly that started the application.
bsp_cleanup() prototype changed.
* startup/bspclean.c:
* include/bsp.h: Add BSP_SMALL_MEMORY.
* startup/linkcmds: Wildcard on .data so C++ links.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac, gdb-init,
preinstall.am, clock/clock.c, console/console.c, console/debugio.c,
include/bsp.h, include/tm27.h, make/custom/mcf5225x.cfg,
start/start.S, startup/bspclean.c, startup/bspstart.c,
startup/init5225x.c, startup/linkcmds, timer/timer.c: New files.
