Update #3285.
Update #3285.
Update #3387.
Update #3285.
Update #3285.
This was used by the not supported "make dist".
Update #3285.
Update #3285.
upgrade to that version.
Close #3387.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
Updates #3520.
Updates #3250.
maintain.
Update #3254.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
Update #3239.
Remove old ISR parameter since is not used by the clock driver shell.
Make an implementation optional.
Update #3139.
Make Clock_driver_support_shutdown_hardware() optional. This avoids
the atexit() support on memory constrained targets.
Adding modified FreeBSD headers to synchronize RTEMS termios with
FreeBSD. Modify termios to support dedicated input and output baud for
termios structure. Updated BSPs to use dedicated input and output baud
in termios structure. Updated tools to use dedicated input and output
baud in termios structure. Updated termios testsuites to use dedicated
input and output baud in termios structure.
Close #2897.
Change the testsuite configuration files to hold state information about
a test. The states are:
exclude - Do not build the test
expected-fail - The test is expected to fail
indeterminate - The test may pass or may fail
A message is printed just after the test's BEGIN message to indicate
there is a special state for the test. No state message means the test
is expected to pass.
This support requires tests are correctly written to the use standard
support to begin and end a test.
updates #2570.
Update #2408.
The size of the sample executables without this option were:
94272 1680 7664 103616 194c0 base_sp.exe
108144 1648 7216 117008 1c910 hello.exe
32528 1216 4912 38656 9700 minimum.exe
113056 1760 7776 122592 1dee0 nsecs.exe
98000 1680 7696 107376 1a370 ticker.exe
95984 1712 11056 108752 1a8d0 unlimited.exe
202224 2272 7840 212336 33d70 cdtest.exe
The size of the sample executables with this option enabled were:
86224 1648 7616 95488 17500 base_sp.exe
98512 1600 7152 107264 1a300 hello.exe
24032 1184 4864 30080 7580 minimum.exe
105520 1728 7712 114960 1c110 nsecs.exe
90112 1648 7632 99392 18440 ticker.exe
86576 1664 10992 99232 183a0 unlimited.exe
185952 2128 7760 195840 2fd00 cdtest.exe
Update #2502.
Notepads where a feature of RTEMS' tasks that simply functioned in
the same way as POSIX keys or threaded local storage (TLS). They were
introduced well before per task variables, which are also deprecated,
and were barely used in favor of their POSIX alternatives.
In addition to their scarce usage, Notepads took up unnecessary memory.
For each task:
- 16 32-bit integers were allocated.
- A total of 64 bytes per task per thread.
This is especially critical in low memory and safety-critical applications.
They are also defined as uint32_t, and therefore are not guaranteed to
hold a pointer.
Lastly, they are not portable solutions for SMP and uniprocessor systems,
like POSIX keys and TLS.
updates #2493.
Update #2408.
Update #2408.
do
echo $b
# echo $g
-i $b
done
