Change the testsuite configuration files to hold state information about
a test. The states are:
exclude - Do not build the test
expected-fail - The test is expected to fail
indeterminate - The test may pass or may fail
A message is printed just after the test's BEGIN message to indicate
there is a special state for the test. No state message means the test
is expected to pass.
This support requires tests are correctly written to the use standard
support to begin and end a test.
Update #2695.
warnings
updates #2572.
Update #2408.
The size of the sample executables without this option were:
95264 1680 8928 105872 19d90 base_sp.exe
109184 1648 8512 119344 1d230 hello.exe
32608 1216 4912 38736 9750 minimum.exe
575040 5584 20400 601024 92bc0 fileio.exe
114528 1760 9024 125312 1e980 nsecs.exe
194864 2048 9520 206432 32660 paranoia.exe
99120 1680 8944 109744 1acb0 ticker.exe
97520 1712 12352 111584 1b3e0 unlimited.exe
869136 21920 16016 907072 dd740 cxx_iostream.exe
203264 2256 9104 214624 34660 cdtest.exe
197120 2176 10752 210048 33480 capture.exe
The size of the sample executables with this option enabled were:
86768 1632 8864 97264 17bf0 base_sp.exe
99776 1584 8448 109808 1acf0 hello.exe
23808 1168 4864 29840 7490 minimum.exe
557808 5552 20080 583440 8e710 fileio.exe
107168 1728 8976 117872 1cc70 nsecs.exe
186032 2016 9456 197504 30380 paranoia.exe
91408 1632 8896 101936 18e30 ticker.exe
88336 1648 12288 102272 18f80 unlimited.exe
178768 2192 8752 189712 2e510 cxx_iostream.exe
186528 2128 9008 197664 30420 cdtest.exe
186640 2112 10688 199440 30b10 capture.exe
Notepads where a feature of RTEMS' tasks that simply functioned in
the same way as POSIX keys or threaded local storage (TLS). They were
introduced well before per task variables, which are also deprecated,
and were barely used in favor of their POSIX alternatives.
In addition to their scarce usage, Notepads took up unnecessary memory.
For each task:
- 16 32-bit integers were allocated.
- A total of 64 bytes per task per thread.
This is especially critical in low memory and safety-critical applications.
They are also defined as uint32_t, and therefore are not guaranteed to
hold a pointer.
Lastly, they are not portable solutions for SMP and uniprocessor systems,
like POSIX keys and TLS.
updates #2493.
Update #2408.
Update #2408.
do
echo $b
# echo $g
-i $b
done
This prevents a compile-time error in libtests/i2c01.
Fix build error introduced in f535fe5311978af53635c2da8e5cb10ef9d78802.
The first pass at building these was without networking enabled.
This pass addresses that plus accounts for some new BSPs which
needed testsuite.tcfg files and BSPs which could not link tests
which had been added since the first pass.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
Conflicts:
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
for details.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* configure.ac: Remove RTEMS_CANONICAL_TARGET_CPU.
Remove AC_ARG_VAR([RTEMS_BSP],[]).
Add RTEMS_ENV_RTEMSBSP.
* include/bsp.h startup/init5206e.c:
* mcf5206elite/tools/runtest: Fix typo where license said
found in found in.
* startup/init5206e.c: Remove warnings.
