PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* console/console.c, i2c/i2c.c, i2c/i2cdrv.c, include/bsp.h,
include/i2c.h, nvram/nvram.c, startup/bspstart.c,
startup/init5206e.c, tod/ds1307.c: Convert to using c99 fixed size
types.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Pickup files from ../../m68k/shared instead of
../shared. Reformat.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
* Makefile.am: Reflect having changed libcpu/m68k/mcf5206/console.rel
to libcpu/m68k/mcf5206/mcfuart.rel
* Makefile.am: Merge-in console/Makefile.am, i2c/Makefile.am,
nvram/Makefile.am, startup/Makefile.am, tod/Makefile.am,
wrapup/Makefile.am.
Use automake compilation rules.
* console/Makefile.am, i2c/Makefile.am, nvram/Makefile.am,
startup/Makefile.am, tod/Makefile.am, wrapup/Makefile.am:
Remove.
* wrapup/Makefile.am: Reflect changes to libcpu.
* startup/Makefile.am: Ditto.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* Makefile.am: Reworked.
* console/Makefile.am: Misc cleanups and fixes.
* i2c/Makefile.am: Misc cleanups and fixes.
* nvram/Makefile.am: Misc cleanups and fixes.
* tod/Makefile.am: Misc cleanups and fixes.
* Makefile.am: Misc cleanups and fixes.
* console/Makefile.am: Remove all: $(ARCH)..
* i2c/Makefile.am: Remove all: $(ARCH)..
* nvram/Makefile.am: Remove all: $(ARCH)..
* startup/Makefile.am: Remove all: $(ARCH)..
* tod/Makefile.am: Remove all: $(ARCH)..
* wrapup/Makefile.am: Remove all: $(ARCH).
Remove bogus wildcard from CPU_PIECES..
* Makefile.am: Cosmetics.
* i2c/Makefile.am: Cosmetics.
* nvram/Makefile.am: Cosmetics.
* start/Makefile.am: Cosmetics.
* tod/Makefile.am: Cosmetics.
* README, console/console.c, i2c/i2c.c, i2c/i2cdrv.c, include/bsp.h,
include/ds1307.h, include/i2c.h, include/i2cdrv.h, include/nvram.h,
nvram/nvram.c, start/start.S, startup/bspclean.c, startup/bspstart.c,
startup/gdbinit, startup/init5206e.c, startup/linkcmds,
startup/linkcmds.flash, tod/ds1307.c, tod/todcfg.c, tools/runtest:
URL for license changed.
* console/console.c, start/start.S, startup/bspclean.c,
startup/bspstart.c, startup/init5206e.c: Correct copyright
statements.
i2c/Makefile.am: Reflect having moved automake.
nvram/Makefile.am: Reflect having moved automake.
tod/Makefile.am: Reflect having moved automake.
* runtest: Add fileio to list of interactive tests.
* startup/Makefile.am: Remove USE_INIT_FINI.
