Update #3285.
Updates #3520.
Update #2408.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
* Makefile.am, startup/linkcmds, startup/linkcmds.flash: Use top level
shared bsp_get_work_area() implementation.
* Makefile.am, configure.ac, start/start.S, startup/linkcmds: Add use
of bsp_get_work_area() in its own file and rely on BSP Framework to
perform more initialization. Remove unnecessary includes of
rtems/libio.h and rtems/libcsupport.h.
* startup/bspstart.c: Removed.
* startup/linkcmds, startup/linkcmds.flash: Add wildcard to
gcc_except_table section so programs compiled with gcc 4.3.x can
link.
* startup/linkcmds: Handle .data.* sections
* startup/linkcmds, startup/linkcmds.flash: Add sections required by
newer gcc versions.
* startup/linkcmds, startup/linkcmds.flash: Add new bss sections .bss.*
and .gnu.linkonce.b*.
* README, console/console.c, i2c/i2c.c, i2c/i2cdrv.c, include/bsp.h,
include/ds1307.h, include/i2c.h, include/i2cdrv.h, include/nvram.h,
nvram/nvram.c, start/start.S, startup/bspclean.c, startup/bspstart.c,
startup/gdbinit, startup/init5206e.c, startup/linkcmds,
startup/linkcmds.flash, tod/ds1307.c, tod/todcfg.c, tools/runtest:
URL for license changed.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* New BSP for MCF5206eLITE evaluation board BSP.
* ChangeLog, README, bsp_specs, configure.ac, console/console.c,
console/.cvsignore, i2c/i2c.c, i2c/i2cdrv.c, i2c/.cvsignore,
include/bsp.h, include/bspopts.h.in, include/coverhd.h,
include/.cvsignore, nvram/nvram.c, nvram/.cvsignore, start/start.S,
start/.cvsignore, startup/bspclean.c, startup/bspstart.c,
startup/linkcmds.flash, startup/.cvsignore, times, tod/ds1307.c,
tod/todcfg.c, tod/.cvsignore, tools/.cvsignore, tools/configure.ac,
tools/runtest, tools/changes, wrapup/.cvsignore, .cvsignore:
New files.
