startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake
compilation rules.
* clock/Makefile.am, console/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am: Remove.
* startup/Makefile.am: Ditto.
* startup/Makefile.am: Remove USE_INIT_FINI.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Include
compile.am
converted to automake.
that converts the a29k to automake.
This patch contains
* An initial merger of the libcpu/a29k stuff you sent yesterday. AFAIS,
most code inside them seems to be empty stubs. One file even contains a
function called mips_*** which might indicate that this part might
contain mips code or the code the initial porter used as template for
porting. Unfortunately, I don't know anything about the a29k so I can't
comment on the details.
* A dummy bsp_specs to libbsp/29k/portsw
* An update to the automake files related to the a29k.
Note:
* This patch is completely untested, because I don't have a toolchain
for it.
* The files in libcpu/a29k include bsp.h => The libbsp vs. libcpu-issue
hits again.
