closes #2546.
closes #2546.
* Makefile.am, configure.ac, clock/ckinit.c, startup/bspstart.c,
startup/linkcmds: Add use of bsp_get_work_area() in its own file and
rely on BSP Framework to perform more initialization. Remove
unnecessary includes of rtems/libio.h and rtems/libcsupport.h.
* clock/ckinit.c: The Shared Memory Driver no longer requires the
special IOCTL in Clock_control. This was a hack which has existed
since before the Classic API Timer Manager was implemented. All
implementations of and references to Clock_control were removed.
* clock/ckinit.c, console/duart.c, timer/timer.c: Reflect changes
to rtems/motorola/*.h.
* clock/ckinit.c, include/bsp.h, startup/bspstart.c: Eliminate copies
of the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* clock/ckinit.c, startup/bspstart.c, timer/timer.c: Convert to
using c99 fixed size types.
* clock/ckinit.c, startup/bspstart.c, timer/timer.c, timer/timerisr.S:
URL for license changed.
like signal dispatching.
