* console/leds.c: Remove warnings.
* Makefile.am: Remove build-variant support.
* console/leds.c: Fix prototype of led_putnum().
* startup/linkcmds: Add new bss sections .bss.* and .gnu.linkonce.b*.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* include/bsp.h: Include <rtems/motorola/mc68230.h> instead of <motorola/mc68230.h>.
* include/bsp.h: Include <rtems/motorola/mc68681.h> instead of <motorola/mc68681.h>.
* timer/timer.c: Include <rtems/rtems/motorola/mc68230.h> instead of
* console/console.c: Include <rtems/ringbuf.h> instead of <ringbuf.h>.
* console/duart.c: Include <rtems/ringbuf.h> instead of <ringbuf.h>.
* clock/ckinit.c, startup/bspstart.c, timer/timer.c: Convert to
using c99 fixed size types.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Pickup files from ../../m68k/shared instead of
../shared. Reformat.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake
compilation rules.
* clock/Makefile.am, console/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am: Remove.
* wrapup/Makefile.am: Reflect changes to libcpu.
* startup/Makefile.am: Ditto.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* bsp_specs: Remove *lib:.
* clock/ckinit.c, startup/bspstart.c, timer/timer.c, timer/timerisr.S:
URL for license changed.
* startup/Makefile.am: Remove USE_INIT_FINI.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
