enable FPU, if POSIX init task present
explicitly disable all edge port interrupts
* startup/init548x.c: Comment out junk from end of #endif.
* configure.ac: Add RTEMS_BSP_LINKCMDS.
* make/custom/m5484FireEngine.cfg: Remove RTEMS_LINKCMDS.
* make/custom/COBRA5475.cfg: Remove RTEMS_LINKCMDS.
* make/custom/genmcf548x.inc: Remove LDFLAGS.
* startup/linkcmds: Remove (Renamed into linkcmds).
* startup/linkcmds.m5484FireEngine: New (Renamed from linkcmds).
* Makefile.am: Rework linkcmds handling.
* make/custom/genmcf548x.inc: Remove RTEMS_BSP_FAMILY.
* make/custom/genmcf548x.inc: New (Renamed from genmcf548x.cfg).
* make/custom/genmcf548x.cfg: Removed.
* make/custom/COBRA5475.cfg, make/custom/m5484FireEngine.cfg:
Include make/custom/genmcf548x.inc.
* make/custom/genmcf548x.cfg: New (relocated from /make/custom).
* make/custom/m5484FireEngine.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
initialization tasks need them.
* start/start.S: Update for boot_card command line change.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared stub coverhd.h
* include/coverhd.h: Removed.
* configure.ac: Move M5484FIREENGINE defines from *.cfg into
bspopts.h.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* clock/clock.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
PR 1322/bsps
* include/bspopts.h.in: Remove.
PR 1322/bsps
* configure.ac, include/bspopts.h.in: Make letting boot_card() handle
work area allocation mandatory. Rename
RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to BSP_BOOTCARD_OPTIONS.
* Makefile.am, configure.ac, include/bspopts.h.in: Use standardized
bsp_cleanup() which can optionally print a message, poll for user to
press key, and call bsp_reset(). Using this eliminates the various
bsp_cleanup() implementations which had their own implementation and
variety of string constants.
* startup/bspclean.c: Removed.
* include/bsp.h: Remove unnecessary boilerplate comments.
* Makefile.am, startup/bspstart.c, startup/init548x.c,
startup/linkcmds, startup/linkcmds.m5484FireEngine.flash: Use top
level shared bsp_get_work_area() implementation.
* Makefile.am, configure.ac, include/bspopts.h.in, startup/bspstart.c,
startup/linkcmds, startup/linkcmds.m5484FireEngine.flash: Add use of
bsp_get_work_area() in its own file and rely on BSP Framework to
perform more initialization. Remove unnecessary includes of
rtems/libio.h and rtems/libcsupport.h.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
* timer/timer.c: Convert to "bool".
* timer/timer.c: Eliminate empty function from every benchmark timer
driver. Fix spelling.
* timer/timer.c: Rename timer driver methods to follow RTEMS
programming conventions.
* startup/bspstart.c: Fixed nested extern declarations.
* startup/bspstart.c: Add missing prototypes.
* startup/init548x.c: Converted to UNIX line endings.
* Makefile.am: Do not build .rel files. Reduces code bloat.
* ChangeLog, startup/linkcmds, startup/linkcmds.m5484FireEngine.flash:
Formatting.
