line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
warnings
These files were left after running the script in the previous patch.
Add doxygen to the header files in the genmcf548x/include directory.
According to the manual the application must use unique and
non-overlapping level and priority definitions for enabled interrupts.
* include/bsp.h: Remove unnecessary boilerplate comments.
* include/bsp.h: Review of all bsp_cleanup() implementations. In this
phase, all prototypes were removed from bsp.h and empty
implementations were removed and made to use the shared stub.
added genmcf548x BSP
