* | bsps: Clock_driver_support_install_isr() | Sebastian Huber | 2017-09-18 | 1 | -4/+2 |
| | | | | | | | Remove old ISR parameter since is not used by the clock driver shell. Make an implementation optional. Update #3139. | ||||
* | bsps: Convert clock drivers to use a timecounter | Alexander Krutwig | 2015-05-20 | 1 | -0/+2 |
| | | | | Update #2271. | ||||
* | bsp/genmcf548x: Use bsp_interrupt_vector_enable() | Sebastian Huber | 2013-12-16 | 1 | -6/+4 |
* | bsp/genmcf548x: Add initial values for INTC_ICRn | Sebastian Huber | 2013-12-16 | 1 | -2/+0 |
| | | | | | According to the manual the application must use unique and non-overlapping level and priority definitions for enabled interrupts. | ||||
* | get desired clock rate for proper source | Thomas Doerfler | 2010-03-27 | 1 | -1/+4 |
* | add network support, various corrections | Thomas Doerfler | 2009-10-15 | 1 | -12/+11 |
* | 2008-09-30 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-30 | 1 | -1/+1 |
| | | | | | * clock/clock.c: include "../../../shared/clockdrv_shell.h". * Makefile.am: Reflect changes above. | ||||
* | added variant to gen68360 BSP | Thomas Doerfler | 2008-07-11 | 1 | -0/+104 |
added genmcf548x BSP |
