* README, clock/Makefile.am, clock/ckinit.c, clock/clock.c:
Clock driver updated to use shell driver mechanism.
* clock/ckinit.c: Removed.
* clock/clock.c: New file.
* Makefile.am: Removed unneeded blank line.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
to driver attach routine.
significant things:
and PowerPC
same code base.
Bob Wisdon <bobwis@ascweb.co.uk> and Chris Johns <ccj@acm.org>
to resolve a random network lockup problem.
ckinit.c:
Occasional network lockups have been noted when the PIT has a higher
interrupt request level than the CPM. The SCC1 bit in the CISR is set
even though the SCC1 interrupt handler is not active. This blocks
interrupts from SCC1 (and all other CPM sources) and locks up the
system. It has not been determined whether the error is within the
68360 or in the RTEMS interrupt support assembler code. The solution,
for now, is to set both PIT and CPM interrupt request levels to the same
value (4).
network.c:
Set CPM transmitter buffer pointer (_tbptr) to beginning of frame
before restarting transmitter. Don't retire transmitter buffer
descriptors belonging to the restarted frame.
that contains:
* Removes MKLIB
handling)
when setting up receive buffer descriptors and when unmasking interrupts.
./bootstrap
that contains:
* The fix for the gen68360/network/Makefile.am
* automatically set permissions to 755 to scripts/buildall and
scripts-ada/buildall (I remembered a trick to achieve this :).
* automake support for libbsp/* and libcpu/* (Attn: This part will
finally break old-style configuration for all non-public cpus)
NOTES:
* This patch has only been tested for a random selection of BSPs (I
haven't rebuilt all toolchains yet).
* This patch is against rtem-cvs as of this morning (MET).
patch -p1 <rtems-rc-20000118-5.diff
cvs rm -f ./c/src/lib/libbsp/Makefile.in
cvs rm -f ./c/src/lib/libbsp/shmdr/Makefile.in
cvs rm -f ./c/src/lib/libcpu/Makefile.in
cvs add ./c/src/lib/libbsp/Makefile.am
cvs add ./c/src/lib/libbsp/shmdr/Makefile.am
cvs add ./c/src/lib/libcpu/Makefile.am
./bootstrap
converted to automake.
Some excellent sleuthing by Bob Wisdom <bobwis@ascweb.co.uk> revealed
that an empty mbuf at the end of a packet chain would cause the `retire'
function to blow up. Moving the line of code which bumps the transmit
buffer descriptor pointer fixes the problem. Some additional cleanup of
the sendpacket function was also completed.
for the gen68360 that let it work with ELF and C++ exceptions. This
was used as the basis for changes to EVERY m68k bsp_specs and linkcmds.
Before this modification is over, the layout of the starting stack,
heap, and workspace will likely be modified for every m68k BSP. Then
they will all be very similar.
that converts the libbsp/i386 subdirectory to full automake.
<corsepiu@faw.uni-ulm.de>.
--target=m68k-rtems \
--enable-cxx \
--disable-posix \
--enable-rdbg \
--disable-networking \
--enable-multiprocessing \
--disable-tests
At the request of kjoutwater@west.raytheon.com I'm submitting the
following patch.
c/src/lib/libbsp/m68k/gen68360/console/console.c
Allow console baud rate to be set by debugger/downloader.
c/src/lib/libbsp/m68k/gen68360/startup/init68360.c
Add support for generic 68360 with static RAM.
following patch.
In another attempt to get C++ exceptions working on the gen68360 target
I tried building for the m68k-elf target. All the tools built and
installed properly as did all of RTEMS. No applications would run,
though -- not even hello.exe!
It turns out the problem was in the linker script. The alignment was in
the wrong place.
Here's a patch. Exceptions still don't work, but at least I can get
some things working with the ELF format now.
which fixes a couple of bugs in RTEMS's old style Makefile.ins, which
apparently were introduced by moving the start directories and not
having adapted the Makefile.ins.
patch -p1 < rtems-rc-19991203-10.diff
I got tired of having strange clock rates (e.g. #define
CONFIGURE_MICROSECONDS_PER_TICK 52489) and drifting times-of-day with
the gen68360 BSP so I changed the way the programmable-interval clock
interrupt works. The new version will have some jitter in the intervals
between individual calls to the rtems_clock_tick routine, but the
long-term average will match the CONFIGURE_MICROSECONDS_PER_TICK
Addtional major bugs:
code size.
work with m68k-elf on late model versions of binutils (990901+)
without overlapping or missing section errors.
initialization is only done once.
<eric@cls.usask.ca>.
