code size.
work with m68k-elf on late model versions of binutils (990901+)
without overlapping or missing section errors.
initialization is only done once.
<eric@cls.usask.ca>.
dependencies of "Makefile".
--enable-maintainer-mode.
ncurses, and zlib for RTEMS.
link even if they do not actually support Ada interrupts.
I added __INSIDE_RTEMS_BSD_TCPIP_STACK__ that trips all the needed
macro definitions for a network driver.
future.
cd <rtems-source-tree>
all bsp_specs.
I'd like to make the following change which adds the m360 structure
information to the debugging symbols in the final executable. This
makes it much easier to use the debugger to look at the elements of
the m360 structure.
network interface names. This change does not introduce any
compatibility problems.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
and automake.
reorg-bsp_specs.sh script.
significantly.
If you're getting close to a new snaphot, here's something that
might be useful to add to the BSP README notes for systems with
networking.
add support for changing the baudrate.
by newlib.
component.
Here are some patches to the gen68360 BSP. The improvements include:
Boot prom run-time selection of DRAM size (1/4/16 Mbytes)
Full 32-bit ethernet address obtained from boot prom.
Updated README.
based on the GNU tools. This usually involved correcting the
type of bsp_start(), bsp_cleanup(), adjusting the start code to
call the right start routine (the shared boot_card()), and then
removing code from bsp_start() which was performed in the new
boot_card()/main() path.
Here's another small patch. The changes to socket.h are to provide
some definitions that UNIX BSD socket programmers expect. The
memcpy.c contains a memcpy routine optimized for the CPU32+. When I
run the ttcp benchmark with this routine I get host->68360 transfers
around 165 kbytes/sec (about a 25% improvement) and 68360->host
transfers of around 290 kbytes/sec (about a 50% improvement).
While trying to work through this problem I decided that the
build-time selection of the console I/O operation (polling or
interrupt) was too clumsy. Here's a patch that allows run-time
(actually init-time) selection of the console I/O mode.
It also shows the need for another `flags' or `options' field in
the rtems_driver_address_table structure...
"gmake debug".
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
