link even if they do not actually support Ada interrupts.
I added __INSIDE_RTEMS_BSD_TCPIP_STACK__ that trips all the needed
macro definitions for a network driver.
future.
cd <rtems-source-tree>
all bsp_specs.
I'd like to make the following change which adds the m360 structure
information to the debugging symbols in the final executable. This
makes it much easier to use the debugger to look at the elements of
the m360 structure.
network interface names. This change does not introduce any
compatibility problems.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
and automake.
reorg-bsp_specs.sh script.
significantly.
If you're getting close to a new snaphot, here's something that
might be useful to add to the BSP README notes for systems with
networking.
add support for changing the baudrate.
by newlib.
component.
Here are some patches to the gen68360 BSP. The improvements include:
Boot prom run-time selection of DRAM size (1/4/16 Mbytes)
Full 32-bit ethernet address obtained from boot prom.
Updated README.
based on the GNU tools. This usually involved correcting the
type of bsp_start(), bsp_cleanup(), adjusting the start code to
call the right start routine (the shared boot_card()), and then
removing code from bsp_start() which was performed in the new
boot_card()/main() path.
Here's another small patch. The changes to socket.h are to provide
some definitions that UNIX BSD socket programmers expect. The
memcpy.c contains a memcpy routine optimized for the CPU32+. When I
run the ttcp benchmark with this routine I get host->68360 transfers
around 165 kbytes/sec (about a 25% improvement) and 68360->host
transfers of around 290 kbytes/sec (about a 50% improvement).
While trying to work through this problem I decided that the
build-time selection of the console I/O operation (polling or
interrupt) was too clumsy. Here's a patch that allows run-time
(actually init-time) selection of the console I/O mode.
It also shows the need for another `flags' or `options' field in
the rtems_driver_address_table structure...
"gmake debug".
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
for the network driver attach entry point.
1) In my haste to add C++ constructor/destructors to the 68360
linkcmds scripts I managed to break all existing 68360 programs.
Linker scripts which actually produce a working executable are
contained below. The problem was that the constructor/destructors
weren't included before the etext symbol.
On top of that Eric and I appear to have problems with attachments:
2) In deciphering the above problem I think I stumbled across the
reason you've had with patches mailed from me. I noticed that the
linkcmds (and linkcmds.bootp) scripts in the latest distribution have
a control-M (carriage return) at the end of each line. Could you
check the files below before installing them in the distribution and
see that there aren't returns in the files? Maybe if I send
everything as a tar attatchment things will work better.
properly reflect the const on the buffer pointer being passed in.
interpreted at the right point per Eric Norum's discovery:
The problem with the my previous `fix' for adding linker commands
was with the ordering of the options to the linker.
For example, to make a larger heap size, the application Makefile would
CFLAGS_LD = -Wl,--defsym -Wl,HeapSize=0x40000
The command passed to the linker would be :
m68k-rtems-ld .... -T xxx/linkcmds .... --defsym HeapSize=0x40000 .....
This doesn't work because the script in linkcmds inserts a default
value for HeapSize if HeapSize is not defined by the time the linker
looks at the linkcmds script.
The solution seems to be to move the -T linkcmds%s in the bsp_specs
file out of the link specfication and into the lib specification -- a
little unorthodox, perhaps, but it seems to work!
switch which lets the user specify a different linker script.
