* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* start/start.S: Update for boot_card command line change.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* configure.ac: Move PGH360, GEN68360, GEN68360_040
defines from *.cfg into bspopts.h.
* timer/timer.c: Eliminate uses of old benchmark timer names.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* clock/clock.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* include/bsp.h: Remove unnecessary boilerplate comments.
* Makefile.am, include/bsp.h, startup/init68360.c, startup/linkcmds,
startup/linkcmds.bootp, startup/linkcmds.prom: Use top level shared
bsp_get_work_area() implementation.
* Makefile.am, configure.ac, start/start.S: Add use of
bsp_get_work_area() in its own file and rely on BSP Framework to
perform more initialization. Remove unnecessary includes of
rtems/libio.h and rtems/libcsupport.h.
* startup/bspstart.c: Removed.
* Makefile.am, include/bsp.h: Review of all bsp_cleanup()
implementations. In this phase, all prototypes were removed from
bsp.h and empty implementations were removed and made to use the
shared stub.
* startup/bspclean.c: Removed.
* spi/mc68360_spidrv.c: Convert to "bool".
* spi/m360_spi.c, timer/timer.c: Convert to "bool".
* timer/timer.c: Eliminate empty function from every benchmark timer
driver. Fix spelling.
* timer/timer.c: Rename timer driver methods to follow RTEMS
programming conventions.
* clock/clock.c: Move extern outside of braces.
added genmcf548x BSP
* console/console.c: Eliminate copies of switches to convert termios
Bxxx constants to xxx as an integer. Use the shared
termios_baud_to_number() routine to do the same conversion.
* Makefile.am: Rework to avoid .rel files.
* startup/bspstart.c: Refactored and renamed initialization routines to
rtems_initialize_data_structures, rtems_initialize_before_drivers,
rtems_initialize_device_drivers, and
rtems_initialize_start_multitasking. This opened the sequence up so
that bootcard() could provide a more robust and flexible framework
which is easier to explain and understand. This also lays the
groundwork for sharing the division of available memory between the
RTEMS workspace and heap and the C library initialization across all
BSPs.
* Makefile.am: Remove all references to console_reserve_resources and
termios_reserve_resources.
* console/consolereserveresources.c: Removed.
* startup/linkcmds, startup/linkcmds.bootp, startup/linkcmds.prom: Add
wildcard to gcc_except_table section so programs compiled with gcc
4.3.x can link.
* clock/clock.c, include/bsp.h, startup/bspstart.c: Eliminate copies of
the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field
from CPU Table to Configuration Table. Eliminate CPU Table from all
ports. Delete references to CPU Table in all forms.
* Makefile.am, startup/bspstart.c: Moved most of the remaining CPU
Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* startup/linkcmds: Handle .data.* sections
* bsp_specs: Remove qrtems_debug.
* Makefile.am: Add dummy printk support so all tests link.
* startup/bspstart.c: Remove assignments of
Cpu_table.do_zero_of_workspace to TRUE since TRUE is the default
value in boot_card.c
* network/network.c: Use ioctl_command_t as arg in ioctl-functions.
* Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a
file and simplified initialization.
* Makefile.am: Remove superfluous -DASM.
sections required by newer gcc versions.
