* startup/linkcmds, startup/linkcmds.bootp, startup/linkcmds.prom: Add
sections required by newer gcc versions.
* Makefile.am: Add preinstall.am.
* include/bsp.h: New header guard.
* startup/alloc360.c: Eliminate warnings.
* startup/init68360.c: Add _RomBase declaration.
* include/bsp.h, startup/init68360.c: Correct type of symbols from
linkcmds to compile with gcc 4.x.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
new bss sections .bss.* and .gnu.linkonce.b*.
* startup/linkcmds: Add .gnu.linkonce.b.*.
* network/network.c: Include errno.h as a consequence of recent updates
to BSD header files.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* c/src/lib/libbsp/m68k/gen68360/clock/clock.c,
c/src/lib/libbsp/m68k/gen68360/console/console.c,
c/src/lib/libbsp/m68k/gen68360/console/consolereserveresources.c,
c/src/lib/libbsp/m68k/gen68360/network/network.c,
c/src/lib/libbsp/m68k/gen68360/startup/alloc360.c,
c/src/lib/libbsp/m68k/gen68360/startup/init68360.c,
c/src/lib/libbsp/m68k/gen68360/timer/timer.c: Include
<rtems/m68k/m68360.h> instead of <m68360.h>.
* include/bsp.h, network/network.c, startup/bspstart.c,
startup/init68360.c, timer/timer.c: Convert to using c99 fixed size
types.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Pickup files from ../../m68k/shared instead of
../shared. Reformat.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
PR 562/bsps
* Makefile.am: Remove references to m68k-gdbstub.c,
rtems-gdbstub-glue.c.
network/Makefile.am, startup/Makefile.am, timer/Makefile.am.
Use automake-compilation rules.
* clock/Makefile.am, console/Makefile.am, network/Makefile.am,
startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am:
Remove.
* wrapup/Makefile.am: Reflect changes to libcpu.
* Makefile.am: Remove non-existing file "times" from EXTRA_DIST.
* configure.ac: Add AM_CONDITIONAL(HAS_FPSP).
* startup/Makefile.am: Ditto.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* network/Makefile.am: Cosmetics.
