<eric@cls.usask.ca>.
dependencies of "Makefile".
--enable-maintainer-mode.
future.
cd <rtems-source-tree>
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
Here are some patches to the gen68360 BSP. The improvements include:
Boot prom run-time selection of DRAM size (1/4/16 Mbytes)
Full 32-bit ethernet address obtained from boot prom.
Updated README.
based on the GNU tools. This usually involved correcting the
type of bsp_start(), bsp_cleanup(), adjusting the start code to
call the right start routine (the shared boot_card()), and then
removing code from bsp_start() which was performed in the new
boot_card()/main() path.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
Change label names so they can be seen from the debugger.
Provide a start symbol -- gets rid of a loader warning message.
Also, I ran across a nasty problem the first time I tried
downloading and running an application compiled with the new
snapshot. To make a very long story short, the `start' in
...../m68k/gen6860/start360/start360.s must not be global. The
change is simple -- just remove the
.globl start
from start360.s.
was done based on the 3.6.0 release and had to be autoconf'ed locally.
It is turned on is the bsp enables it and it is not explicitly disabled
via the configure option --disable-tcpip. As many warnings as possible
were removed locally after the code was merged. Only the gen68360
and mvme136 bsps were compiled this way.
The ka9q port and network driver were submitted by Eric Norum
(eric@skatter.USask.Ca).
The network demo programs are not included in the tree at this point.
be resolved.
Contact information:
W. Eric Norum
Saskatchewan Accelerator Laboratory
107 North Road
University of Saskatchewan
Saskatoon, Saskatchewan, CANADA
S7N 5C6
