path: root/c/src/lib/libbsp/m68k/gen68360/start360 (follow)
* Update from Eric Norum.Joel Sherrill1997-04-161-3/+7
* Added ka9q tcpip stack and network driver for the gen68360. This effortJoel Sherrill1997-04-091-3/+17
| | | | | | | | | | | | | was done based on the 3.6.0 release and had to be autoconf'ed locally. It is turned on is the bsp enables it and it is not explicitly disabled via the configure option --disable-tcpip. As many warnings as possible were removed locally after the code was merged. Only the gen68360 and mvme136 bsps were compiled this way. The ka9q port and network driver were submitted by Eric Norum (eric@skatter.USask.Ca). The network demo programs are not included in the tree at this point.
* added global statement for start entry pointJoel Sherrill1997-04-071-0/+1
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+56
| | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved.
* Updates from Eric Norum.Joel Sherrill1996-05-011-17/+29
* some instructions altered for older binutilsJoel Sherrill1996-03-211-8/+8
* Generic 68360 BSP (gen360) submitted by: W. Eric Norum <eric@skatter.usask.ca>.Joel Sherrill1996-03-061-0/+393
Contact information: W. Eric Norum Saskatchewan Accelerator Laboratory 107 North Road University of Saskatchewan Saskatoon, Saskatchewan, CANADA S7N 5C6
