--target=m68k-rtems \
--enable-cxx \
--disable-posix \
--enable-rdbg \
--disable-networking \
--enable-multiprocessing \
--disable-tests
dependencies of "Makefile".
--enable-maintainer-mode.
I added __INSIDE_RTEMS_BSD_TCPIP_STACK__ that trips all the needed
macro definitions for a network driver.
future.
cd <rtems-source-tree>
network interface names. This change does not introduce any
compatibility problems.
this week until now.
It consists of 3 parts:
1. a patch
2. a perl script (acpolish)
plural).
configure scripts etc.
added by acpolish.
To apply this:
./rtems-polish.sh
Later:
cvs add contrib
cvs add contrib/acpolish
cvs commit
Here are some patches to the gen68360 BSP. The improvements include:
Boot prom run-time selection of DRAM size (1/4/16 Mbytes)
Full 32-bit ethernet address obtained from boot prom.
Updated README.
subdirectory Makefiles.
used.
individual Makefile.
problem (reported by Eric)
for the network driver attach entry point.
