Update #3285.
Update #3285.
updates #2566.
For the main BSP:
The size of the sample executables without this option were:
117616 1728 27312 146656 23ce0 base_sp.exe
108256 1696 26912 136864 216a0 hello.exe
29728 1216 23344 54288 d410 minimum.exe
535168 5632 38800 579600 8d810 fileio.exe
136624 1808 27424 165856 287e0 nsecs.exe
192128 2112 27920 222160 363d0 paranoia.exe
121472 1728 27344 150544 24c10 ticker.exe
120304 1760 30752 152816 254f0 unlimited.exe
859008 21600 34400 915008 df640 cxx_iostream.exe
207536 2320 27488 237344 39f20 cdtest.exe
185136 2224 29136 216496 34db0 capture.exe
The size of the sample executables with this option enabled were:
110384 1696 27248 139328 22040 base_sp.exe
100080 1648 26832 128560 1f630 hello.exe
22496 1184 23296 46976 b780 minimum.exe
519376 5600 38464 563440 898f0 fileio.exe
130432 1776 27360 159568 26f50 nsecs.exe
184448 2064 27856 214368 34560 paranoia.exe
114976 1696 27280 143952 23250 ticker.exe
112448 1712 30672 144832 235c0 unlimited.exe
190368 2256 27136 219760 35a70 cxx_iostream.exe
191312 2176 27408 220896 35ee0 cdtest.exe
175216 2160 29072 206448 32670 capture.exe
For the gen68360_040 BSP variant:
112624 1712 27328 141664 22960 base_sp.exe
101584 1680 26912 130176 1fc80 hello.exe
29936 1184 23344 54464 d4c0 minimum.exe
530080 5616 38800 574496 8c420 fileio.exe
131552 1792 27424 160768 27400 nsecs.exe
161296 2080 27920 191296 2eb40 paranoia.exe
116400 1712 27344 145456 23830 ticker.exe
115312 1728 30752 147792 24150 unlimited.exe
861952 21488 34384 917824 e0140 cxx_iostream.exe
202336 2128 27472 231936 38a00 cdtest.exe
179968 2208 29136 211312 33970 capture.exe
105360 1664 27264 134288 20c90 base_sp.exe
93360 1616 26832 121808 1dbd0 hello.exe
21840 1152 23296 46288 b4d0 minimum.exe
513920 5568 38464 557952 88380 fileio.exe
125312 1760 27360 154432 25b40 nsecs.exe
153632 2048 27856 183536 2ccf0 paranoia.exe
109856 1680 27280 138816 21e40 ticker.exe
107376 1680 30672 139728 221d0 unlimited.exe
185040 2128 27104 214272 34500 cxx_iostream.exe
186032 2064 27376 215472 349b0 cdtest.exe
170016 2144 29072 201232 31210 capture.exe
For the pgh360 BSP variant:
117424 1728 27312 146464 23c20 base_sp.exe
108064 1696 26912 136672 215e0 hello.exe
29536 1216 23344 54096 d350 minimum.exe
534976 5632 38800 579408 8d750 fileio.exe
136432 1808 27424 165664 28720 nsecs.exe
191936 2112 27920 221968 36310 paranoia.exe
121280 1728 27344 150352 24b50 ticker.exe
120096 1760 30752 152608 25420 unlimited.exe
858816 21600 34400 914816 df580 cxx_iostream.exe
207344 2320 27488 237152 39e60 cdtest.exe
184944 2224 29136 216304 34cf0 capture.exe
110176 1696 27248 139120 21f70 base_sp.exe
99888 1648 26832 128368 1f570 hello.exe
22304 1184 23296 46784 b6c0 minimum.exe
519168 5600 38464 563232 89820 fileio.exe
130224 1776 27360 159360 26e80 nsecs.exe
184256 2064 27856 214176 344a0 paranoia.exe
114784 1696 27280 143760 23190 ticker.exe
112256 1712 30672 144640 23500 unlimited.exe
190160 2256 27136 219552 359a0 cxx_iostream.exe
191120 2176 27408 220704 35e20 cdtest.exe
175024 2160 29072 206256 325b0 capture.exe
* make/custom/gen68360.cfg, make/custom/gen68360_040.cfg,
make/custom/pgh360.cfg: Simplify and clean up.
* make/custom/gen68360.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/pgh360.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/gen68360_040.cfg: New (relocated from /make/custom).
* make/custom/gen68360.cfg: New (relocated from /make/custom).
* make/custom/pgh360.cfg: New (relocated from /make/custom).
* custom/av5282.cfg, custom/csb360.cfg, custom/gen68302.cfg,
custom/gen68340.cfg, custom/gen68360.cfg, custom/mcf5206elite.cfg,
custom/mcf5235.cfg, custom/mrm332.cfg, custom/mvme136.cfg,
custom/mvme147.cfg, custom/mvme162.cfg, custom/mvme162lx.cfg,
custom/mvme167.cfg, custom/ods68302.cfg, custom/sim68000.cfg,
custom/simcpu32.cfg, custom/uC5282.cfg: Change CCFLAGS to use the
-mcpu= option for Coldfires now supported in GCC 4.3.0.
2008-06-10 Matthew Riek <matthew.riek@ibiscomputer.com.au>
* custom/mcf52235.cfg: New.
application. Share as much logic as possible for .num file and size information. Let BSPs provide custom rules to tranform executable from linked .exe to downloadable RTEMS Application Loadable File (RALF) .ralf file.
* custom/av5282.cfg, custom/bare.cfg, custom/dmv152.cfg,
custom/gen405.cfg, custom/gen5200.cfg, custom/gen68302.cfg,
custom/gen68340.cfg, custom/gen68360.cfg, custom/helas403.cfg,
custom/hurricane.cfg, custom/i386ex.cfg, custom/idp.cfg,
custom/mbx8xx.cfg, custom/mcf5206elite.cfg, custom/mcf5235.cfg,
custom/mcp750.cfg, custom/mpc8260ads.cfg, custom/mrm332.cfg,
custom/mtx603e.cfg, custom/mvme136.cfg, custom/mvme147.cfg,
custom/mvme162.cfg, custom/mvme162lx.cfg, custom/mvme167.cfg,
custom/mvme2100.cfg, custom/mvme2307.cfg, custom/mvme5500.cfg,
custom/ods68302.cfg, custom/pc386.cfg, custom/psim.cfg,
custom/rbtx4925.cfg, custom/sim68000.cfg, custom/simcpu32.cfg,
custom/ss555.cfg, custom/ts_386ex.cfg, custom/uC5282.cfg:
CFLAGS_OPTIMIZE_V = -O2.
* custom/efi332.cfg, custom/gen68340.cfg, custom/gen68360.cfg,
custom/mrm332.cfg: Use more proper CPU models so libcpu knows more.
* Per PR260 eliminate use of make-target-options. This impacted
RTEMS allowing a distinction between the CPU32 and CPU32+ in the
SuperCore and required that the m68k optimized memcpy be moved
to libcpu.
* custom/gen68360.cfg: Remove make-target-options.
* custom/erc32.cfg: Add comment on -mno-v8, -mcypress.
* custom/gen68302.cfg: Comment out LIBC_LIB[C|M].
* custom/gen68340.cfg: Comment out LIBC_LIB[C|M].
* custom/gen68360.cfg: Comment out LIBC_LIB[C|M].
* custom/idp.cfg: Comment out LIBC_LIB[C|M].
* custom/mvme162.cfg: Comment out LIBC_LIB[C|M].
* custom/ods68302.cfg: Comment out LIBC_LIB[C|M].
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
cpuopts.h.
to disabled.
problems at runtime.
that contains:
* Removes MKLIB
handling)
* the PACKHEX etc problem
* prevents the *.rels being removed inside the build-tree
* a typo which only shows for when MP is activated
* Alters some custom/*cfg files
<corsepiu@faw.uni-ulm.de> which does the following:
This is the configuration cleanup patch:
Main changes:
* TARGET_ARCH removed
* target.cfg.in moved to c/make/target.cfg.in (Only configured once for
all BSPs of a target)
* BARE_XXX variables appended to bsp.cfg.in
* autogen renamed to bootstrap
* removed stray variables from make/custom/*.cfg
rm c/src/make/target.cfg.in
cp autogen bootstrap
mkdir c/make
cp make/target.cfg.in c/make/target.cfg.in
rm make/target.cfg.in
rm autogen
patch -p1 < rtems-rc-19991105-1.diff
Here's a patch to get rid of the `#define RTEMS__mcpu32p__ 1' when
gen68360.cfg is being used as a companion for gen68360_040.cfg. The
old version worked because of the order of the conditional tests in
m68k.h (the check for __mc68040__ is before the test for
RTEMS__mcpu32p__) , but I think it might have been a little confusing
to others just getting started.
I found that my 68040/68360 test programs would not run even after
I fixed the `wrong BSP' problem.
It seems that there's a bug in the interrupt handling code for
processors with hardware interrupt stacks (e.g. 68040). The wrong
status register was getting pushed on the stack for the `return
from exception' to call _ISR__Dispatch. This ended up making
the context switch code run on the interrupt stack, so interrupt-driven
context switches would always fail.
I guess that no one has tried running any of the RTEMS-4.0 snapshots
on a 68040 machine!
Anyhow, here are the patches for
1) gen68360.cfg --- to fix the `wrong-BSP' problem.
2) m68k/cpu_asm.s --- to fix the hardware interrupt stack problem.
With these patches in place, the network demo programs run on my
68040/68360 system. The paranoia program runs with no failures,
defects nor flaws.
all the targets:
breaking CXX support.
handling.
after minor changes.)
insecure about.
external packages.
may be broken).
disturb now.
--enable-* flags).
--enable-gcc28 are given.
mvme162.cfg-bug.
eliminates the need to build the entire application with the
STACK_CHECKER_ON macro defined.
Here are some patches to the gen68360 BSP. The improvements include:
Boot prom run-time selection of DRAM size (1/4/16 Mbytes)
Full 32-bit ethernet address obtained from boot prom.
Updated README.
I've included a version of make/custom/gen68360.cfg that works with
this. Note that I've removed the option of using `-m68020
-msoft-float -mno-bitfield' as an alternative to using `-mcpu32'.
The alternative won't work with the new system (since it predefines
__mc68020__ and not __mcpu32__), and didn't really work before anyway
(since the newlib that gets linked was built with `-m68020
-msoft-float' and so could contain bitfield operators).
While trying to work through this problem I decided that the
build-time selection of the console I/O operation (polling or
interrupt) was too clumsy. Here's a patch that allows run-time
(actually init-time) selection of the console I/O mode.
It also shows the need for another `flags' or `options' field in
the rtems_driver_address_table structure...
