* | New patch from Eric Norum plus some minor mods by Joel. | Joel Sherrill | 2000-01-13 | 1 | -2/+1 |
* | Eric Norum <eric@cls.usask.ca> submitted linker script and bsp_specs | Joel Sherrill | 2000-01-12 | 1 | -1/+5 |
| | | | | | | | | for the gen68360 that let it work with ELF and C++ exceptions. This was used as the basis for changes to EVERY m68k bsp_specs and linkcmds. Before this modification is over, the layout of the starting stack, heap, and workspace will likely be modified for every m68k BSP. Then they will all be very similar. | ||||
* | Renaming all BSP specific startXXX directories to use the same name (start). | Joel Sherrill | 1999-11-19 | 1 | -2/+2 |
* | Incorporated Ralf Corsepius' idea for new -q flags to properly support | Joel Sherrill | 1998-02-11 | 1 | -2/+7 |
| | | | | "gmake debug". | ||||
* | Moved -qnolinkcmds option so arguments passed on the command line are | Joel Sherrill | 1997-12-20 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | | | | | | interpreted at the right point per Eric Norum's discovery: The problem with the my previous `fix' for adding linker commands was with the ordering of the options to the linker. For example, to make a larger heap size, the application Makefile would CFLAGS_LD = -Wl,--defsym -Wl,HeapSize=0x40000 The command passed to the linker would be : m68k-rtems-ld .... -T xxx/linkcmds .... --defsym HeapSize=0x40000 ..... This doesn't work because the script in linkcmds inserts a default value for HeapSize if HeapSize is not defined by the time the linker looks at the linkcmds script. The solution seems to be to move the -T linkcmds%s in the bsp_specs file out of the link specfication and into the lib specification -- a little unorthodox, perhaps, but it seems to work! | ||||
* | Modified bsp_specs per Eric Norum's suggestion to handle -qnolinkcmds | Joel Sherrill | 1997-12-19 | 1 | -1/+1 |
| | | | | switch which lets the user specify a different linker script. | ||||
* | Modified to search RTEMS library before Newlib C library. | Joel Sherrill | 1997-10-08 | 1 | -1/+1 |
* | Switched to new style which does not require hackspecs.awk. | Joel Sherrill | 1997-08-28 | 1 | -29/+13 |
* | new file used by gcc 2.8.x -specs option | Joel Sherrill | 1997-01-28 | 1 | -0/+34 |
