Update #2408.
The size of the sample executables without this option were:
97296 5088 21408 123792 1e390 base_sp.exe
110720 5056 21008 136784 21650 hello.exe
34240 4512 17296 56048 daf0 minimum.exe
543344 8992 32896 585232 8ee10 fileio.exe
116304 5168 21520 142992 22e90 nsecs.exe
194352 5456 22000 221808 36270 paranoia.exe
101152 5088 21440 127680 1f2c0 ticker.exe
99472 5120 24848 129440 1f9a0 unlimited.exe
847312 24960 28512 900784 dbeb0 cxx_iostream.exe
200672 5680 21584 227936 37a60 cdtest.exe
193312 5584 23232 222128 363b0 capture.exe
The size of the sample executables with this option enabled were:
89376 5056 21360 115792 1c450 base_sp.exe
101872 5008 20944 127824 1f350 hello.exe
27584 4464 17232 49280 c080 minimum.exe
527520 8960 32560 569040 8aed0 fileio.exe
109424 5136 21456 136016 21350 nsecs.exe
185984 5424 21952 213360 34170 paranoia.exe
93968 5056 21376 120400 1d650 ticker.exe
90944 5072 24784 120800 1d7e0 unlimited.exe
176832 5600 21248 203680 31ba0 cxx_iostream.exe
184480 5536 21504 211520 33a40 cdtest.exe
183376 5520 23168 212064 33c60 capture.exe
Update #2408.
Update #2408.
do
echo $b
# echo $g
-i $b
done
not updated.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
Termios notifies now the driver about an inactive transmit with the
length argument set to zero.
Conflicts:
for details.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* include/bsp.h:
* timer/timer.c: Include <rtems/btimer.h>.
* start/start.S: Fix mismatched comment.
* console/m340uart.c, startup/init68340.c: Remove warnings.
* make/custom/gen68340.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/gen68340.cfg: New (relocated from /make/custom).
* console/console.c: Include <rtems/termiostypes.h>.
Add missing prototype.
* console/console.c: Reflect termios_baud_to_number having been
renamed to rtems_termios_baud_to_number.
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* start/start.S: Update for boot_card command line change.
* Makefile.am: Remove unnecessary copy of cpu_asm.S
* console/Modif_cpu_asm.S: Removed.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* timer/timer.c: Eliminate uses of old benchmark timer names.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* start/startfor340only.S: Remove (Unused).
