2006-10-17 | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* include/m68349.inc, start/start.S, startup/dumpanic.c: Convert to utf-8. | |||||
2006-10-17 | Convert to utf-8 | Ralf Corsepius | 3 | -3/+3 | |
2006-03-17 | Remove eof include file | Ralf Corsepius | 1 | -1/+0 | |
2006-02-08 | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -2/+6 | |
* startup/linkcmds: Add sections required by newer gcc versions. | |||||
2006-01-14 | Regenerate. | Ralf Corsepius | 1 | -1/+1 | |
2006-01-12 | Regenerate. | Ralf Corsepius | 1 | -0/+4 | |
2006-01-12 | Remove all-local:. | Ralf Corsepius | 1 | -2/+0 | |
2006-01-12 | Regenerate. | Ralf Corsepius | 1 | -1/+1 | |
2006-01-12 | Cleanup. | Ralf Corsepius | 1 | -1/+0 | |
2006-01-11 | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -67/+6 | |
* Makefile.am: Add preinstall.am. | |||||
2006-01-11 | New. | Ralf Corsepius | 1 | -0/+74 | |
2005-05-26 | 2005-05-26 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+6 | |
* include/bsp.h: New header guard. | |||||
2005-02-12 | 2005-02-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -5/+5 | |
* include/bsp.h: Correct type of symbols from linkcmds to compile with gcc 4.x. | |||||
2005-01-07 | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -4/+8 | |
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | |||||
2005-01-04 | 2005-01-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -2/+6 | |
* console/console.c: Remove warnings. | |||||
2005-01-02 | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -64/+22 | |
* Makefile.am: Remove build-variant support. | |||||
2004-11-26 | 2004-11-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -1/+6 | |
* startup/linkcmds: Add new bss sections .bss.* and .gnu.linkonce.b*. | |||||
2004-09-24 | Fix typo in previous change. | Ralf Corsepius | 1 | -1/+1 | |
2004-09-24 | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Require automake > 1.9. | |||||
2004-04-23 | 2004-04-23 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 3 | -5/+14 | |
PR 610/bsps * Makefile.am: Add include/tm27.h, Cosmetics. * include/tm27.h: Final cosmetics. | |||||
2004-04-22 | 2004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 3 | -15/+40 | |
* include/bsp.h: Split out tmtest27 support. * include/tm27.h: New. | |||||
2004-04-21 | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -10/+5 | |
PR 613/bsps * include/bsp.h: Remove MAX_LONG_TEST_DURATION. | |||||
2004-04-21 | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
PR 614/bsps * include/bsp.h: Remove MAX_SHORT_TEST_DURATION (Unused). | |||||
2004-04-21 | Remove duplicate white lines. | Ralf Corsepius | 4 | -8/+0 | |
2004-04-21 | Remove stray white spaces. | Ralf Corsepius | 14 | -95/+95 | |
2004-04-19 | 2004-04-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -5/+25 | |
* start/start.S: DWARF on the m68k requires that all objects me a multiple of a 16-bit word in length. | |||||
2004-04-15 | Remove stray white spaces. | Ralf Corsepius | 6 | -12/+0 | |
2004-04-02 | * start/start.S: Include <rtems/asm.h> instead of <asm.h>. | Ralf Corsepius | 3 | -2/+7 | |
* start/startfor340only.S: Include <rtems/asm.h> instead of <asm.h>. | |||||
2004-04-01 | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 3 | -4/+11 | |
* console/Modif_cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>. * include/bsp.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * include/bsp.h: Include <rtems/console.h> instead of <console.h>. * include/bsp.h: Include <rtems/iosupp.h> instead of <iosupp.h>. | |||||
2004-03-31 | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 6 | -19/+25 | |
* clock/ckinit.c, console/m340uart.c, include/bsp.h, include/m340uart.h, startup/bspstart.c: Convert to using c99 fixed size types. | |||||
2004-02-19 | 2004-02-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -2/+35 | |
* Makefile.am: Reflect changes to bsp.am. Preinstall dist_project_lib*. | |||||
2004-02-14 | 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* Makefile.am: Reflect changes to bsp.am. | |||||
2004-02-12 | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE. | |||||
2004-02-06 | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -2/+7 | |
* Makefile.am: Pickup files from ../../m68k/shared instead of ../shared. Reformat. | |||||
2004-01-29 | 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS. | |||||
2004-01-28 | .cvsignore: Remove Makefile* | Ralf Corsepius | 1 | -2/+0 | |
2004-01-28 | Remove .cvsignore | Ralf Corsepius | 6 | -12/+0 | |
2004-01-28 | 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* Makefile.am: Distribute start/startfor340only.S. | |||||
2004-01-27 | 2004-01-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 8 | -176/+102 | |
* Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above. | |||||
2004-01-21 | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 3 | -2/+9 | |
* Makefile.am: Add PREINSTALL_DIRS. * wrapup/Makefile.am: Reflect changes to libcpu. | |||||
2004-01-20 | 2004-01-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 4 | -7/+9 | |
* Makefile.am: Remove non-existing file "times" from EXTRA_DIST. * README: Fix minor typo. * wrapup/Makefile.am: Reflect changes to libcpu. | |||||
2004-01-14 | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 3 | -0/+14 | |
* Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * startup/Makefile.am: Ditto. | |||||
2004-01-07 | 2004-01-07 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 4 | -38/+24 | |
* start/Makefile.am: Remove. * Makefile.am: Merge-in start/Makefile.am. * configure.ac: Reflect changes above. | |||||
2004-01-05 | 2004-01-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -7/+7 | |
* wrapup/Makefile.am: Eliminate $(LIB). Use noinst_DATA to trigger building libbsp.a. | |||||
2003-12-13 | 2003-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 3 | -12/+17 | |
* start/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. * startup/Makefile.am: s,${PROJECT_RELEASE}/lib,$(PROJECT_LIB),g. | |||||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 3 | -0/+13 | |
* start/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * startup/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. | |||||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -2/+6 | |
* configure.ac: Require automake >= 1.8, autoconf >= 2.59. | |||||
2003-12-10 | 2003-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 4 | -21/+21 | |
* start/Makefile.am: Misc cleanups and fixes. * startup/Makefile.am: Misc cleanups and fixes. * wrapup/Makefile.am: Misc cleanups and fixes. | |||||
2003-12-03 | 2003-12-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 7 | -19/+26 | |
* Makefile.am: Add preinstallation dirstamp support. * clock/Makefile.am: Cosmetics. * console/Makefile.am: Cosmetics. * startup/Makefile.am: Cosmetics. * timer/Makefile.am: Cosmetics. * wrapup/Makefile.am: Cosmetics. | |||||
2003-12-02 | 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 7 | -6/+15 | |
* clock/Makefile.am: Remove all-local: $(ARCH). * console/Makefile.am: Remove all-local: $(ARCH). * start/Makefile.am: Remove all-local: $(ARCH). * startup/Makefile.am: Remove all-local: $(ARCH). * timer/Makefile.am: Remove all-local: $(ARCH). * wrapup/Makefile.am: Remove all-local: $(ARCH). |
