path: root/c/src/lib/libbsp/m68k/gen68340/include (unfollow)
2018-01-25Remove make preinstallChris Johns7-1032/+0
2017-11-27bsps: Provide <tm27.h> in each BSPSebastian Huber1-0/+1
Since the <tm27.h> is highly BSP-dependent and used only by the tm27 test program we must provide this header file for each BSP. Without the preinstall build target each header file must have a unique source header file. Update #3254.
2017-11-24Remove coverhd.hSebastian Huber1-82/+0
This header file contained timing overhead values which are hard to maintain. Update #3254.
2016-03-30m68k/gen68340/include/bsp.h: Do not include <rtems/iosupp.h>Joel Sherrill1-1/+0
2016-03-29m68k/gen68340: Remove include of <rtems/console.h> from <bsp.h> and fix warningsJoel Sherrill1-1/+0
2016-03-27m68k/gen68340/include/bsp.h: Do not include <rtems/clockdrv.h>Joel Sherrill1-1/+0
2015-07-16Most bsp.h: Switch to LIBBSP_@CPU@_@BSP_FAMILY@_H for guardJoel Sherrill1-2/+2
This was done by the following script run from libbsp: find * -name bsp.h | xargs -e grep -l "#ifndef.*_BSP_H" | while read b do echo $b cpu=`echo $b | cut -d'/' -f1 | tr '[:lower:]' '[:upper:]' ` bsp=`echo $b | cut -d'/' -f2 | tr '[:lower:]' '[:upper:]' ` g="LIBBSP_${cpu}_${bsp}_BSP_H" # echo $g sed -e "s/ifndef _BSP_H/ifndef ${g}/" \ -e "s/define _BSP_H/define ${g}/" \ -i $b done
2014-10-23bsps: Move extern "C" to not cover includesSebastian Huber1-4/+4
2014-10-16m68k/gen68340: Fix warningsJoel Sherrill1-0/+17
2014-03-21gen68340/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill1-16/+0
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns3-3/+3
2014-01-02gen68340: Add doxygen header files.Toma Radu5-0/+48
2012-11-15score: Add RTEMS_FATAL_SOURCE_EXITSebastian Huber1-0/+1
Include <bsp/default-initial-extension.h> in all BSPs. Call rtems_fatal() with RTEMS_FATAL_SOURCE_EXIT as source and the exit() status code as fatal code in every bsp_cleanup(). Move previous bsp_cleanup() code into bsp_fatal_extension().
2012-08-06Revert "Add bspopts.h.in."Gedare Bloom1-31/+0
This reverts commit daffa606cc4a45d93c1f0f4fe365fde0fda6acbb. Conflicts: c/src/lib/libbsp/arm/lpc24xx/include/bspopts.h.in c/src/lib/libbsp/powerpc/mpc55xxevb/include/bspopts.h.in c/src/lib/libbsp/powerpc/qoriq/include/bspopts.h.in Manually deleted conflicting files.
2012-05-24Add bspopts.h.in.Ralf Corsépius1-0/+31
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill4-8/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2012-05-03General - Remove extraneous blank line in license messageJoel Sherrill2-2/+0
Many files had an extra blank line in the license text found in the file header. This patch removes that line. * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * * http://www.rtems.com/license/LICENSE. The script that did this also turned off execute permission when it was turned on incorrectly.
2012-04-16m68k: replace m68k_isr with rtems_isrGedare Bloom1-2/+2
2012-02-01Remove all .cvsignore files.Joel Sherrill1-4/+0
2011-02-112011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius1-1/+1
* include/bsp.h: Use "__asm__" instead of "asm" for improved c99-compliance.
2009-12-17 adapted to new prototype for *_write functionThomas Doerfler1-1/+1
2008-10-022008-10-02 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill1-33/+0
* Makefile.am, preinstall.am: Use shared tm27.h stub. * include/tm27.h: Removed.
2008-09-182008-09-18 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-14/+0
* include/bsp.h: Remove unnecessary boilerplate comments.
2008-09-102008-09-10 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-2/+0
* Makefile.am, include/bsp.h: Review of all bsp_cleanup() implementations. In this phase, all prototypes were removed from bsp.h and empty implementations were removed and made to use the shared stub. * startup/bspclean.c: Removed.
2008-08-312008-08-31 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-1/+1
* console/console.c, include/m340timer.h, timer/timer.c: Eliminate empty function from every benchmark timer driver. Fix spelling.
* console/console.c, include/m340timer.h, timer/timer.c: Rename timer driver methods to follow RTEMS programming conventions.
2008-06-052008-06-05 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill1-2/+1
* console/console.c, include/m340uart.h: Use new shared termios_baud_to_number() routine.
2007-12-112007-12-11 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill1-8/+0
* clock/ckinit.c, include/bsp.h, startup/bspstart.c: Eliminate copies of the Configuration Table. Use the RTEMS provided accessor macros to obtain configuration fields.
2007-12-042007-12-04 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill1-9/+0
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field from CPU Table to Configuration Table. Eliminate CPU Table from all ports. Delete references to CPU Table in all forms.
2006-10-17Convert to utf-8Ralf Corsepius1-1/+1
2006-03-17Remove eof include fileRalf Corsepius1-1/+0
2005-05-262005-05-26 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius1-2/+2
* include/bsp.h: New header guard.
2005-02-122005-02-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-5/+0
* include/bsp.h: Correct type of symbols from linkcmds to compile with gcc 4.x.
2004-04-232004-04-23 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-5/+3
PR 610/bsps * Makefile.am: Add include/tm27.h, Cosmetics. * include/tm27.h: Final cosmetics.
2004-04-222004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2-15/+35
* include/bsp.h: Split out tmtest27 support. * include/tm27.h: New.
2004-04-212004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-10/+0
PR 613/bsps * include/bsp.h: Remove MAX_LONG_TEST_DURATION.
2004-04-212004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-1/+0
PR 614/bsps * include/bsp.h: Remove MAX_SHORT_TEST_DURATION (Unused).
2004-04-21Remove duplicate white lines.Ralf Corsepius1-1/+0
2004-04-21Remove stray white spaces.Ralf Corsepius4-8/+8
2004-04-15Remove stray white spaces.Ralf Corsepius1-3/+0
2004-04-012004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-3/+3
* console/Modif_cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>. * include/bsp.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * include/bsp.h: Include <rtems/console.h> instead of <console.h>. * include/bsp.h: Include <rtems/iosupp.h> instead of <iosupp.h>.
2004-03-312004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2-12/+12
* clock/ckinit.c, console/m340uart.c, include/bsp.h, include/m340uart.h, startup/bspstart.c: Convert to using c99 fixed size types.
2004-01-28.cvsignore: Remove Makefile*Ralf Corsepius1-2/+0
2003-09-292003-09-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-23/+0
* Makefile.am: Merge-in include/Makefile.am. Reflect changes to bsp.am. * include/Makefile.am: Remove. * configure.ac: Reflect changes above.
2003-09-042003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-3/+3
* clock/ckinit.c, console/Modif_cpu_asm.S, console/console.c, console/m340uart.c, include/bsp.h, include/m340timer.h, include/m340uart.h, start/start.S, start/startfor340only.S, startup/bspclean.c, startup/bspstart.c, startup/dumpanic.c, timer/timer.c: URL for license changed.
2003-08-162003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+1
Makefile.am: Reflect having moved automake. clock/Makefile.am: Reflect having moved automake. console/Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. start/Makefile.am: Reflect having moved automake. startup/Makefile.am: Reflect having moved automake. timer/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+0
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
2001-09-282001-09-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
2001-09-272001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
2001-06-182001-06-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-2/+2
* include/Makefile.am: Fix typo in include_HEADERS.
