line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
header file.
Update #3254.
maintain.
Update #3254.
do
echo $b
# echo $g
-i $b
done
Conflicts:
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
* include/bsp.h:
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* include/bsp.h: Remove unnecessary boilerplate comments.
* Makefile.am, include/bsp.h: Review of all bsp_cleanup()
implementations. In this phase, all prototypes were removed from
bsp.h and empty implementations were removed and made to use the
shared stub.
* startup/bspclean.c: Removed.
* console/console.c, include/m340timer.h, timer/timer.c: Eliminate
empty function from every benchmark timer driver. Fix spelling.
* console/console.c, include/m340timer.h, timer/timer.c: Rename timer
driver methods to follow RTEMS programming conventions.
* console/console.c, include/m340uart.h: Use new shared
termios_baud_to_number() routine.
* clock/ckinit.c, include/bsp.h, startup/bspstart.c: Eliminate copies
of the Configuration Table. Use the RTEMS provided accessor macros to
obtain configuration fields.
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field
from CPU Table to Configuration Table. Eliminate CPU Table from all
ports. Delete references to CPU Table in all forms.
* include/bsp.h: New header guard.
* include/bsp.h: Correct type of symbols from linkcmds to compile with
gcc 4.x.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
PR 613/bsps
PR 614/bsps
* console/Modif_cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>.
* clock/ckinit.c, console/m340uart.c, include/bsp.h,
include/m340uart.h, startup/bspstart.c: Convert to using c99 fixed
size types.
Reflect changes to bsp.am.
* clock/ckinit.c, console/Modif_cpu_asm.S, console/console.c,
console/m340uart.c, include/bsp.h, include/m340timer.h,
include/m340uart.h, start/start.S, start/startfor340only.S,
startup/bspclean.c, startup/bspstart.c, startup/dumpanic.c,
timer/timer.c: URL for license changed.
* include/Makefile.am: Fix typo in include_HEADERS.
