2009-02-27 | 2009-02-27 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -178/+0 | |
* Makefile.am: Remove unnecessary copy of cpu_asm.S * console/Modif_cpu_asm.S: Removed. | |||||
2004-04-21 | Remove duplicate white lines. | Ralf Corsepius | 1 | -3/+0 | |
2004-04-21 | Remove stray white spaces. | Ralf Corsepius | 1 | -3/+3 | |
2004-04-15 | Remove stray white spaces. | Ralf Corsepius | 1 | -2/+0 | |
2004-04-01 | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* console/Modif_cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>. * include/bsp.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * include/bsp.h: Include <rtems/console.h> instead of <console.h>. * include/bsp.h: Include <rtems/iosupp.h> instead of <iosupp.h>. | |||||
2003-09-04 | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* clock/ckinit.c, console/Modif_cpu_asm.S, console/console.c, console/m340uart.c, include/bsp.h, include/m340timer.h, include/m340uart.h, start/start.S, start/startfor340only.S, startup/bspclean.c, startup/bspstart.c, startup/dumpanic.c, timer/timer.c: URL for license changed. | |||||
1999-11-17 | Updated copyright notice. | Joel Sherrill | 1 | -2/+1 | |
1998-12-14 | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to rename all | Joel Sherrill | 1 | -0/+0 | |
.s files to .S in conformance with GNU conventions. This is a minor step along the way to supporting automake. | |||||
1998-07-01 | Initial submission of gen68340 BSP (should run on a 68349) from | Joel Sherrill | 1 | -0/+184 | |
Geoffroy Montel <g_montel@yahoo.com>. |
