path: root/c/src/lib/libbsp/m68k/gen68340/configure.in (unfollow)
2001-10-122001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-34/+0
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate.
2001-06-142001-05-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+1
* configure.in: Add bspopts.h. * include/.cvsignore: Add bspopts.h*, stamp-h*. * include/Makefile.am: Use *_HEADERS instead of *H_FILES. * include/bsp.h: Include bspopts.h.
2001-05-112001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
2000-02-08Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-2/+3
that contains: * Removes remaining (now illegal) references to $(SRC) from a couple of Makefile.ams * Removes duplicate AC_CONFIG_SUBDIRS macro from c/configure.in * Moves ENABLE_LIBCDIR into RTEMS_PROG_C[C|XX]_FOR_TARGET (hides LIBCDIR from most configure scripts, i.e. LIBCDIR becomes less visible) * Adds RTEMS_PROG_C[C|XX]_FOR_TARGET and RTEMS_CANONICALIZE_TOOLS to libbsp/*/configure.ins (A minor bug in previous implementations, which only has an impact when switching to GNU/Cygnus canonicalization) * Cleans up several bogus comments. * Removes MKLIB * Switches the version number to 4.5.0 (for testing version number handling)
2000-01-10Patch rtems-rc-20000104-10.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-2/+3
that converts the m68k directory to automake. NOTE: This one is fully tested by building *all* bsps with ../../rtems-rc-20000104/configure \ --target=m68k-rtems \ --prefix=/tmp/rtems \ --enable-cxx \ --disable-posix \ --enable-rdbg \ --disable-networking \ --enable-maintainer-mode \ --enable-multiprocessing \ --disable-tests make
2000-01-10Patch rtems-rc-20000104-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-2/+2
that converts the mips64orion directory to automake. Ralf's Note: This patch demonstrates another kind of supporting the new style of configuration, which avoids having to port all Makefile.ins to automake, but to keep using most old style Makefile.ins.
2000-01-10Patch rtems-rc-20000104-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-5/+10
that converts nearly all of libbsp/sh to automake. Comments follow: 1. Almost full automake support for the libbsp/sh/ subdirectories (exception libbsp/sh/gensh*/wrapup/*) 2. Fixes for libbsp/bare/* 3. Updates to libbsp/* configuration which supports old (autoconf/deep configuration) and new (automake/flat/cascaded configuration) style configuration of libbsp/<cpu>/*
1999-12-13Patch rtems-rc-19991203-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+26
which adds automake support to libbsp/bare.
