path: root/c/src/lib/libbsp/m68k/gen68340/clock (follow)
* Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-02-181-0/+2
* Initial submission of gen68340 BSP (should run on a 68349) fromJoel Sherrill1998-07-012-0/+239
Geoffroy Montel <g_montel@yahoo.com>.
