Close #3250.
Close #4081.
Update #4267.
controller support.
Update #3269.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #2408.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
header file.
Update #3254.
maintain.
Update #3254.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
Update #3239.
Update #2408.
Update #2408.
for details.
* Makefile.am: Remove unnecessary copy of cpu_asm.S
* console/Modif_cpu_asm.S: Removed.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* start/startfor340only.S: Remove (Unused).
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* Makefile.am, configure.ac, clock/ckinit.c, startup/linkcmds: Add use
of bsp_get_work_area() in its own file and rely on BSP Framework to
perform more initialization. Remove unnecessary includes of
rtems/libio.h and rtems/libcsupport.h.
* startup/bspstart.c: Removed.
* Makefile.am, include/bsp.h: Review of all bsp_cleanup()
implementations. In this phase, all prototypes were removed from
bsp.h and empty implementations were removed and made to use the
shared stub.
* startup/bspclean.c: Removed.
* Makefile.am: Rework to avoid .rel files.
