closes #2543.
The size of the sample executables without this option were:
78560 1632 12597120 12677312 c170c0 base_sp.exe
93760 1616 12596720 12692096 c1aa80 hello.exe
31024 1216 12593472 12625712 c0a730 minimum.exe
537104 5552 12608608 13151264 c8ac20 fileio.exe
97888 1728 12597232 12696848 c1bd10 nsecs.exe
179888 2016 12597728 12779632 c30070 paranoia.exe
82864 1648 12597152 12681664 c181c0 ticker.exe
81328 1664 12600560 12683552 c18920 unlimited.exe
841296 21520 12604224 13467040 cd7da0 cxx_iostream.exe
187168 2224 12597296 12786688 c31c00 cdtest.exe
181664 2144 12598944 12782752 c30ca0 capture.exe
The size of the sample executables with this option enabled were:
71280 1616 12597056 12669952 c15400 base_sp.exe
85552 1568 12596656 12683776 c18a00 hello.exe
22272 1168 12593408 12616848 c08490 minimum.exe
521808 5520 12608272 13135600 c86ef0 fileio.exe
91696 1696 12597168 12690560 c1a480 nsecs.exe
172256 1984 12597664 12771904 c2e240 paranoia.exe
76336 1616 12597088 12675040 c167e0 ticker.exe
73296 1632 12600496 12675424 c16960 unlimited.exe
163568 2160 12596960 12762688 c2be40 cxx_iostream.exe
171744 2096 12597216 12771056 c2def0 cdtest.exe
172384 2080 12598880 12773344 c2e7e0 capture.exe
Notepads where a feature of RTEMS' tasks that simply functioned in
the same way as POSIX keys or threaded local storage (TLS). They were
introduced well before per task variables, which are also deprecated,
and were barely used in favor of their POSIX alternatives.
In addition to their scarce usage, Notepads took up unnecessary memory.
For each task:
- 16 32-bit integers were allocated.
- A total of 64 bytes per task per thread.
This is especially critical in low memory and safety-critical applications.
They are also defined as uint32_t, and therefore are not guaranteed to
hold a pointer.
Lastly, they are not portable solutions for SMP and uniprocessor systems,
like POSIX keys and TLS.
updates #2493.
Update #2408.
Update #2408.
do
echo $b
# echo $g
-i $b
done
output.
not updated.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
Conflicts:
for details.
* include/bsp.h:
* timer/timer.c: Include <rtems/btimer.h>.
* make/custom/gen68302.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/gen68302.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* start/start.S: Update for boot_card command line change.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* timer/timer.c: Eliminate uses of old benchmark timer names.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* include/bsp.h: Remove unnecessary boilerplate comments.
