* | All m68k BSPs now build with new ELF style linkcmds. | Joel Sherrill | 2000-01-13 | 1 | -12/+10 |
* | Made sweep of changes to get all BSPs to the same point on the linkcmds | Joel Sherrill | 2000-01-13 | 1 | -2/+1 |
| | | | | and memory layout. Next step is to share the same bsp_pretasking_hook. | ||||
* | Eric Norum <eric@cls.usask.ca> submitted linker script and bsp_specs | Joel Sherrill | 2000-01-12 | 1 | -48/+109 |
| | | | | | | | | for the gen68360 that let it work with ELF and C++ exceptions. This was used as the basis for changes to EVERY m68k bsp_specs and linkcmds. Before this modification is over, the layout of the starting stack, heap, and workspace will likely be modified for every m68k BSP. Then they will all be very similar. | ||||
* | Added more sections and made minor modifications to let the linkcmds | Joel Sherrill | 1999-10-06 | 1 | -1/+7 |
| | | | | | work with m68k-elf on late model versions of binutils (990901+) without overlapping or missing section errors. | ||||
* | Corrected so sections did not overlap with new version of binutils. | Joel Sherrill | 1999-10-05 | 1 | -0/+6 |
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Added .eh_frame, C++ constructor, and C++ destructor sections. | Joel Sherrill | 1998-02-17 | 1 | -0/+18 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | all targets compile .. tony's patches in place | Joel Sherrill | 1995-09-29 | 1 | -0/+1 |
* | added for first time | Joel Sherrill | 1995-06-07 | 1 | -0/+45 |
