2016-01-23 | Obsolete and remove m68k/gen68302 | Joel Sherrill | 1 | -204/+0 | |
closes #2543. | |||||
2015-12-08 | Add RTEMS linker sets | Sebastian Huber | 1 | -0/+2 | |
Update #2408. | |||||
2014-04-22 | bsps: Fix TLS support in linker command files | Sebastian Huber | 1 | -1/+3 | |
The TLS section symbols had wrong values in case of an empty TLS data section and a nonempty TLS BSS section. | |||||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2014-02-04 | bsps: Thread-local storage (TLS) for linkcmds | Sebastian Huber | 1 | -0/+18 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -2/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2008-09-16 | 2008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -4/+4 | |
* Makefile.am, startup/linkcmds: Use top level shared bsp_get_work_area() implementation. | |||||
2008-09-16 | 2008-09-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* Makefile.am, configure.ac, clock/ckinit.c, startup/linkcmds: Add use of bsp_get_work_area() in its own file and rely on BSP Framework to perform more initialization. Remove unnecessary includes of rtems/libio.h and rtems/libcsupport.h. * startup/bspstart.c: Removed. | |||||
2008-03-03 | 2008-03-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* startup/linkcmds: Add wildcard to gcc_except_table section so programs compiled with gcc 4.3.x can link. | |||||
2007-05-03 | 2007-05-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -2/+2 | |
* startup/linkcmds: Handle .data.* sections | |||||
2006-02-08 | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -2/+2 | |
* startup/linkcmds: Add sections required by newer gcc versions. | |||||
2004-11-26 | 2004-11-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+2 | |
* startup/linkcmds: Add new bss sections .bss.* and .gnu.linkonce.b*. | |||||
2003-09-04 | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* clock/ckinit.c, console/console.c, include/bsp.h, include/coverhd.h, start/start.S, startup/bspclean.c, startup/bspstart.c, startup/linkcmds, timer/timer.c: URL for license changed. | |||||
2003-01-20 | mkChangeLogList [-n] | Joel Sherrill | 1 | -0/+10 | |
2002-05-09 | 2001-05-09 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+2 | |
* startup/linkcmds: In support of gcc 3.1, added one of more of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*, .gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections and direction of segments to memory regions may also have been addressed. This was a sweep across all BSPs. | |||||
2000-09-29 | 2000-09-29 Charles-Antoine Gauthier <charles.gauthier@nrc.ca> | Joel Sherrill | 1 | -0/+40 | |
* startup/linkcmds: Added lines so DWARF debug information would be available. Otherwise gdb complains that the offsets for the debug info are incorrect and doesn't load the files. | |||||
2000-06-12 | Merged from 4.5.0-beta3a | Joel Sherrill | 1 | -3/+2 | |
2000-01-13 | All m68k BSPs now build with new ELF style linkcmds. | Joel Sherrill | 1 | -12/+10 | |
2000-01-13 | Made sweep of changes to get all BSPs to the same point on the linkcmds | Joel Sherrill | 1 | -2/+1 | |
and memory layout. Next step is to share the same bsp_pretasking_hook. | |||||
2000-01-12 | Eric Norum <eric@cls.usask.ca> submitted linker script and bsp_specs | Joel Sherrill | 1 | -48/+109 | |
for the gen68360 that let it work with ELF and C++ exceptions. This was used as the basis for changes to EVERY m68k bsp_specs and linkcmds. Before this modification is over, the layout of the starting stack, heap, and workspace will likely be modified for every m68k BSP. Then they will all be very similar. | |||||
1999-11-17 | Updated copyright notice. | Joel Sherrill | 1 | -2/+1 | |
1999-10-06 | Added more sections and made minor modifications to let the linkcmds | Joel Sherrill | 1 | -1/+7 | |
work with m68k-elf on late model versions of binutils (990901+) without overlapping or missing section errors. | |||||
1999-10-05 | Corrected so sections did not overlap with new version of binutils. | Joel Sherrill | 1 | -0/+6 | |
1998-02-17 | updated copyright to 1998 | Joel Sherrill | 1 | -1/+1 | |
1998-02-17 | Added .eh_frame, C++ constructor, and C++ destructor sections. | Joel Sherrill | 1 | -0/+18 | |
1997-10-08 | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1 | -2/+2 | |
1997-04-22 | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1 | -5/+5 | |
of switching to the modified GNU GPL. | |||||
1995-09-29 | all targets compile .. tony's patches in place | Joel Sherrill | 1 | -0/+1 | |
1995-06-07 | added for first time | Joel Sherrill | 1 | -15/+14 | |
