path: root/c/src/lib/libbsp/m68k/gen68302/bsp_specs (follow)
* Moved -qnolinkcmds option so arguments passed on the command line areJoel Sherrill1997-12-201-2/+2
| | | | | | | | | | | | | | | | | | | | | interpreted at the right point per Eric Norum's discovery: The problem with the my previous `fix' for adding linker commands was with the ordering of the options to the linker. For example, to make a larger heap size, the application Makefile would CFLAGS_LD = -Wl,--defsym -Wl,HeapSize=0x40000 The command passed to the linker would be : m68k-rtems-ld .... -T xxx/linkcmds .... --defsym HeapSize=0x40000 ..... This doesn't work because the script in linkcmds inserts a default value for HeapSize if HeapSize is not defined by the time the linker looks at the linkcmds script. The solution seems to be to move the -T linkcmds%s in the bsp_specs file out of the link specfication and into the lib specification -- a little unorthodox, perhaps, but it seems to work!
* Modified bsp_specs per Eric Norum's suggestion to handle -qnolinkcmdsJoel Sherrill1997-12-191-1/+1
| | | | switch which lets the user specify a different linker script.
* Modified to search RTEMS library before Newlib C library.Joel Sherrill1997-10-081-1/+1
* Switched to new style which does not require hackspecs.awk.Joel Sherrill1997-08-281-29/+13
* new file used by gcc 2.8.x -specs optionJoel Sherrill1997-01-281-0/+34
