path: root/c/src/lib/libbsp/m68k/efi68k/include/Makefile.in (follow)
* Removed CONFIG_DIR and PROJECT_HOME directories.Joel Sherrill1998-01-201-1/+1
* Removed include directory at "build" point and the link of this directoryJoel Sherrill1997-10-081-2/+2
| | | | | | to lib/include. Went to using a PROJECT_INCLUDE variable.
* This set of changes is the build of what was required to convert toJoel Sherrill1997-04-011-0/+33
