path: root/c/src/lib/libbsp/m68k/efi68k/Makefile.am (unfollow)
2000-06-12Merged from 4.5.0-beta3aJoel Sherrill1-2/+2
2000-01-10Patch rtems-rc-20000104-10.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
that converts the m68k directory to automake. NOTE: This one is fully tested by building *all* bsps with ../../rtems-rc-20000104/configure \ --target=m68k-rtems \ --prefix=/tmp/rtems \ --enable-cxx \ --disable-posix \ --enable-rdbg \ --disable-networking \ --enable-maintainer-mode \ --enable-multiprocessing \ --disable-tests make
2000-01-10Patch rtems-rc-20000104-6.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
that converts the i960 directory to automake. The same kind of libbsp configuration as for the mips64orion, now for the i960. In addition to libbsp configuration this patch also contains two fixes for cvme961.cfg and rxgen960.cfg, which contained non-functional make-exes. (Now both bsps probably have the same issues with linking c++ applications as the gensh2 has, but this is a different open issue not tried to be solved now). The rxgen961 also seems to have problems with its start file, because linking apps fails due to not finding start.o. (Note that libbsp/i960/rxgen960 lacks a start subdirectory!). I leave solving this issue to you :)
2000-01-10Patch rtems-rc-20000104-5.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
that converts the no_cpu directory to automake.
2000-01-10Patch rtems-rc-20000104-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+17
that converts nearly all of libbsp/sh to automake. Comments follow: 1. Almost full automake support for the libbsp/sh/ subdirectories (exception libbsp/sh/gensh*/wrapup/*) 2. Fixes for libbsp/bare/* 3. Updates to libbsp/* configuration which supports old (autoconf/deep configuration) and new (automake/flat/cascaded configuration) style configuration of libbsp/<cpu>/*
