Per John S. Gwynne <jgwynne@mrcday.com>, there are no longer any
users of these boards so we are removing them.
* efi332/.cvsignore, efi332/ChangeLog, efi332/Makefile.am,
efi332/README, efi332/bsp_specs, efi332/configure.ac, efi332/times,
efi332/clock/.cvsignore, efi332/clock/Makefile.am,
efi332/clock/ckinit.c, efi332/console/.cvsignore,
efi332/console/Makefile.am, efi332/console/console.c,
efi332/include/.cvsignore, efi332/include/bsp.h,
efi332/include/efi332.h, efi332/misc/dotests, efi332/misc/gdbinit68,
efi332/misc/interr.c, efi332/spurious/.cvsignore,
efi332/spurious/Makefile.am, efi332/spurious/spinit.c,
efi332/start/.cvsignore, efi332/start/Makefile.am,
efi332/start/except_vect_332_ROM.S, efi332/start/ram_init.ld,
efi332/start/ram_init.sed, efi332/start/start.c,
efi332/startup/.cvsignore, efi332/startup/Makefile.am,
efi332/startup/bspclean.c, efi332/startup/bspstart.c,
efi332/startup/linkcmds, efi332/startup/linkcmds_ROM,
efi332/timer/.cvsignore, efi332/timer/Makefile.am,
efi332/timer/timer.c, efi332/wrapup/.cvsignore,
efi332/wrapup/Makefile.am, efi68k/.cvsignore, efi68k/ChangeLog,
efi68k/Makefile.am, efi68k/README, efi68k/bsp_specs,
efi68k/configure.ac, efi68k/times, efi68k/clock/.cvsignore,
efi68k/clock/Makefile.am, efi68k/clock/ckinit.c,
efi68k/console/.cvsignore, efi68k/console/Makefile.am,
efi68k/console/console.c, efi68k/include/.cvsignore,
efi68k/include/16550.h, efi68k/include/DP8570A.h,
efi68k/include/bsp.h, efi68k/include/efi68k.h,
efi68k/spurious/.cvsignore, efi68k/spurious/Makefile.am,
efi68k/spurious/spinit.c, efi68k/start/.cvsignore,
efi68k/start/start.c, efi68k/startup/.cvsignore,
efi68k/startup/Makefile.am, efi68k/startup/bspclean.c,
efi68k/startup/bspstart.c, efi68k/startup/efi68k_tcp.c,
efi68k/startup/efi68k_wd.c, efi68k/startup/linkcmds,
efi68k/startup/m68k-stub.c, efi68k/startup/setvec.c,
efi68k/timer/.cvsignore, efi68k/timer/Makefile.am,
efi68k/timer/timer.c, efi68k/wrapup/.cvsignore,
efi68k/wrapup/Makefile.am: Removed.
* start/Makefile.am: Remove.
* Makefile.am: Merge-in start/Makefile.am.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* spurious/Makefile.am: Cosmetics.
* spurious/Makefile.am: Remove all-local: $(ARCH).
PR 503/bsps
* clock/ckinit.c, include/bsp.h, startup/efi68k_tcp.c, timer/timer.c:
Do not include DP8570A.h from bsp.h but still install it. This avoids
polluting the namespace.
Reflect changes to bsp.am.
* bsp_specs: Remove *lib:.
PR 483/bsps
* start/start.c, startup/bspstart.c: Spurious interrupt handlers cannot
be installed until RTEMS has initialized the vector table.
* clock/ckinit.c, console/console.c, include/16550.h,
include/DP8570A.h, include/bsp.h, spurious/spinit.c,
startup/bspclean.c, startup/bspstart.c, startup/efi68k_tcp.c,
startup/efi68k_wd.c, startup/setvec.c, timer/timer.c: URL for license
changed.
spurious/Makefile.am: Reflect having moved automake.
* startup/Makefile.am: Remove USE_INIT_FINI.
* include/DP8570A.h, include/bsp.h, start/start.c,
startup/efi68k_tcp.c: Rename tcp_init() to bsp_tcp_init()
to avoid conflict with TCP/IP stack internal routine.
* startup/linkcmds*: Add FreeBSD sysctl() sections.
* spurious/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* console/console.c, start/start.c: Removed warnings.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* wrapup/Makefile.am: PR217 required that the idle task be moved to
libcpu so it could be more acutely aware of the CPU model. This
file was modified to pick up the idle task from there.
* spurious/Makefile.am: Use .$(OBJEXT) instead of .o.
* Per PR260 eliminate use of make-target-options. This impacted
RTEMS allowing a distinction between the CPU32 and CPU32+ in the
SuperCore and required that the m68k optimized memcpy be moved
to libcpu.
* wrapup/Makefile.am: Pick up memcpy.o from libcpu.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* spurious/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.in: Remove.
* include/Makefile.am: Fix typo in include_HEADERS.
