* | Removed include directory at "build" point and the link of this directory | Joel Sherrill | 1997-10-08 | 1 | -2/+2 | |
| | | | | | | to lib/include. Went to using a PROJECT_INCLUDE variable. | |||||
* | eliminated potential for overfilling buffer on read | Joel Sherrill | 1997-09-15 | 1 | -1/+0 | |
* | Switched to new style which does not require hackspecs.awk. | Joel Sherrill | 1997-08-28 | 1 | -29/+13 | |
* | Corrected typo | Joel Sherrill | 1997-08-04 | 1 | -1/+1 | |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 9 | -43/+43 | |
| | | | | of switching to the modified GNU GPL. | |||||
* | Fixed path which points to shared directory for all BSPs. | Joel Sherrill | 1997-04-16 | 1 | -1/+1 | |
* | Switched all bsps which had an implementation of sbrk.c which only | Joel Sherrill | 1997-04-15 | 1 | -1/+1 | |
| | | | | returned an error to using a single shared copy of this file. | |||||
* | Removed many BSPs' copy of setvec.c and let them share the same | Joel Sherrill | 1997-04-15 | 1 | -1/+1 | |
| | | | | implementation as all m68k BSPs. | |||||
* | removed noreturn from prototype to avoid warnings. | Joel Sherrill | 1997-04-07 | 3 | -3/+28 | |
* | added cast to eliminate warning. | Joel Sherrill | 1997-04-07 | 1 | -1/+1 | |
* | This set of changes is the build of what was required to convert to | Joel Sherrill | 1997-04-01 | 10 | -0/+457 | |
| | | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved. | |||||
* | updates from John Gwynne | Joel Sherrill | 1997-03-11 | 2 | -0/+358 | |
* | updates from John Gwynne | Joel Sherrill | 1997-03-11 | 13 | -50/+592 | |
* | All RTEMS system call implementation renamed to be __rtems_*. | Joel Sherrill | 1997-01-29 | 1 | -4/+4 | |
* | new file used by gcc 2.8.x -specs option | Joel Sherrill | 1997-01-28 | 1 | -0/+34 | |
* | changed reboot to a macro to avoid the "noreturn returns" warning. | Joel Sherrill | 1996-06-18 | 1 | -0/+4 | |
* | added initial posix configuration support | Joel Sherrill | 1996-05-28 | 1 | -1/+1 | |
* | Dispersal of internal thread handler resulted in the SYSI task being | Joel Sherrill | 1996-02-21 | 1 | -1/+1 | |
| | | | | | | only required in a multiprocessor system. It was replace by the MPCI Receive Server. As a result, the CPU Table field for extra stack for the SYSI task was changed to be extra stack for the MPCI Receive Server. | |||||
* | changes remerged after lost in disk crash -- recovered from snapshot, ↵ | Joel Sherrill | 1995-12-20 | 1 | -1/+0 | |
| | | | | partially recovered working tree, etc | |||||
* | file lost in crash and re-added | Joel Sherrill | 1995-12-19 | 1 | -0/+193 | |
* | SPARC port passes all tests | Joel Sherrill | 1995-10-30 | 2 | -16/+11 | |
* | Actually adding efi bsp's from John Gwynne after forgetting to | Joel Sherrill | 1995-09-20 | 11 | -0/+1393 | |
commit them. |
