* | Patch from John S. Gwynne <jgwynne@mrcday.com> to correct minor | Joel Sherrill | 1999-03-16 | 1 | -3/+12 |
| | | | | | | | | | | | problems that prevented the 19990302 snapshot from running on the efi332. I'm happy to report that rtems-19990302 is running on the efi332 board. I have enclosed a few minor patches below to the efi332 bsp. All patches are within that library but one. make/custom/efi332.cfg has a patch to select the right CPU_CFLAGS (at one time -m68332 was a problem... -mcpu32 or -m68332 work fine now). | ||||
* | Ralf Corsepius reported a number of missing CVS Id's: | Joel Sherrill | 1998-01-16 | 1 | -1/+1 |
| | | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose. | ||||
* | updates from John Gwynne | Joel Sherrill | 1997-03-11 | 1 | -0/+110 |
