2007-05-11 | 2007-05-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 20 | -2045/+0 | |
* dmv152/.cvsignore, dmv152/ChangeLog, dmv152/Makefile.am, dmv152/bsp_specs, dmv152/configure.ac, dmv152/preinstall.am, dmv152/times, dmv152/clock/ckinit.c, dmv152/console/console.c, dmv152/include/.cvsignore, dmv152/include/bsp.h, dmv152/include/coverhd.h, dmv152/include/tm27.h, dmv152/spurious/spinit.c, dmv152/startup/bspclean.c, dmv152/startup/bspstart.c, dmv152/startup/linkcmds, dmv152/startup/vmeintr.c, dmv152/timer/timer.c, dmv152/timer/timerisr.S: Removed. | |||||
2007-05-03 | 2007-05-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -2/+6 | |
* startup/linkcmds: Handle .data.* sections | |||||
2007-04-12 | 2007-04-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -5/+6 | |
* bsp_specs: Remove qrtems_debug. | |||||
2007-04-02 | 2007-04-02 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -1/+5 | |
* Makefile.am: Add dummy printk support so all tests link. | |||||
2007-03-11 | 2007-03-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -1/+6 | |
* startup/bspstart.c: Remove assignments of Cpu_table.do_zero_of_workspace to TRUE since TRUE is the default value in boot_card.c | |||||
2007-01-08 | Regenerate. | Ralf Corsepius | 1 | -2/+2 | |
2006-12-02 | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: New BUG-REPORT address. | |||||
2006-11-15 | 2006-11-15 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -1/+6 | |
* Makefile.am: Merge c_rtems_main() into boot_card(). This eliminated a file and simplified initialization. | |||||
2006-10-17 | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* Makefile.am: Remove superfluous -DASM. | |||||
2006-10-17 | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+6 | |
* configure.ac: Require autoconf-2.60. Require automake-1.10. | |||||
2006-03-17 | Remove eof include file | Ralf Corsepius | 2 | -2/+0 | |
2006-02-08 | 2006-02-08 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -2/+6 | |
* startup/linkcmds: Add sections required by newer gcc versions. | |||||
2006-01-14 | Regenerate. | Ralf Corsepius | 1 | -1/+1 | |
2006-01-12 | Regenerate. | Ralf Corsepius | 1 | -0/+4 | |
2006-01-12 | Remove all-local:. | Ralf Corsepius | 1 | -2/+0 | |
2006-01-12 | Regenerate. | Ralf Corsepius | 1 | -1/+1 | |
2006-01-12 | Cleanup. | Ralf Corsepius | 1 | -1/+0 | |
2006-01-11 | 2006-01-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -47/+6 | |
* Makefile.am: Add preinstall.am. | |||||
2006-01-11 | New. | Ralf Corsepius | 1 | -0/+54 | |
2005-05-26 | 2005-05-26 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+6 | |
* include/bsp.h: New header guard. | |||||
2005-01-07 | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -5/+9 | |
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | |||||
2005-01-02 | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2 | -75/+23 | |
* Makefile.am: Remove build-variant support. | |||||
2004-11-26 | 2004-11-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -1/+6 | |
* startup/linkcmds: Add new bss sections .bss.* and .gnu.linkonce.b*. | |||||
2004-09-24 | Fix typo in previous change. | Ralf Corsepius | 1 | -1/+1 | |
2004-09-24 | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Require automake > 1.9. | |||||
2004-04-23 | 2004-04-23 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 3 | -4/+13 | |
PR 610/bsps * Makefile.am: Add include/tm27.h, Cosmetics. * include/tm27.h: Final cosmetics. | |||||
2004-04-22 | 2004-04-22 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 3 | -22/+47 | |
* include/bsp.h: Split out tmtest27 support. * include/tm27.h: New. | |||||
2004-04-21 | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -10/+5 | |
PR 613/bsps * include/bsp.h: Remove MAX_LONG_TEST_DURATION. | |||||
2004-04-21 | 2004-04-21 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
PR 614/bsps * include/bsp.h: Remove MAX_SHORT_TEST_DURATION (Unused). | |||||
2004-04-21 | Remove duplicate white lines. | Ralf Corsepius | 3 | -3/+0 | |
2004-04-21 | Remove stray white spaces. | Ralf Corsepius | 5 | -25/+25 | |
2004-04-15 | Remove stray white spaces. | Ralf Corsepius | 2 | -2/+0 | |
2004-04-08 | 2004-04-08 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -2/+9 | |
* dmv152/include/bsp.h: Include <rtems/zilog/z8536.h> instead of <zilog/z8536.h>. * dmv152/include/bsp.h: Include <rtems/zilog/z8530.h> instead of <zilog/z8530.h>. | |||||
2004-04-02 | * timer/timerisr.S: Include <rtems/asm.h> instead of <asm.h>. | Ralf Corsepius | 2 | -1/+5 | |
2004-04-01 | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 3 | -5/+13 | |
* include/bsp.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * include/bsp.h: Include <rtems/console.h> instead of <console.h>. * include/bsp.h: Include <rtems/iosupp.h> instead of <iosupp.h>. * include/bsp.h: Include <rtems/vmeintr.h> instead of <vmeintr.h>. * startup/vmeintr.c: Include <rtems/vmeintr.h> instead of <vmeintr.h>. | |||||
2004-03-31 | 2004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 8 | -46/+52 | |
* clock/ckinit.c, console/console.c, include/bsp.h, spurious/spinit.c, startup/bspstart.c, startup/vmeintr.c, timer/timer.c: Convert to using c99 fixed size types. | |||||
2004-02-19 | 2004-02-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -2/+35 | |
* Makefile.am: Reflect changes to bsp.am. Preinstall dist_project_lib*. | |||||
2004-02-14 | 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* Makefile.am: Reflect changes to bsp.am. | |||||
2004-02-12 | 2004-02-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE. | |||||
2004-02-06 | 2004-02-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -2/+8 | |
* Makefile.am: Pickup files from ../../m68k/shared instead of ../shared. Reformat. | |||||
2004-01-29 | 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS. | |||||
2004-01-28 | .cvsignore: Remove Makefile* | Ralf Corsepius | 1 | -2/+0 | |
2004-01-28 | Remove .cvsignore | Ralf Corsepius | 6 | -12/+0 | |
2004-01-27 | 2004-01-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 9 | -208/+117 | |
* Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, spurious/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, spurious/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above. | |||||
2004-01-21 | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 3 | -2/+9 | |
* Makefile.am: Add PREINSTALL_DIRS. * wrapup/Makefile.am: Reflect changes to libcpu. | |||||
2004-01-20 | 2004-01-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -2/+6 | |
2004-01-14 | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 3 | -0/+14 | |
* Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * startup/Makefile.am: Ditto. | |||||
2004-01-13 | 2004-01-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -2/+4 | |
* start/.cvsignore: Remove. | |||||
2004-01-13 | 2004-01-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 4 | -37/+23 | |
* start/Makefile.am: Remove. * Makefile.am: Merge-in start/Makefile.am. * configure.ac: Reflect changes above. | |||||
2004-01-05 | 2004-01-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -7/+7 | |
* wrapup/Makefile.am: Eliminate $(LIB). Use noinst_DATA to trigger building libbsp.a. |
