path: root/c/src/lib/libbsp/m68k/dmv152/configure.ac (follow)
* 2004-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-291-1/+1
| | | | * configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
* 2004-01-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-271-8/+2
| | | | | | | | | | | * Makefile.am: Merge-in clock/Makefile.am, console/Makefile.am, spurious/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules. * clock/Makefile.am, console/Makefile.am, spurious/Makefile.am, startup/Makefile.am, timer/Makefile.am, wrapup/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2004-01-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-131-1/+0
| | | | | | * start/Makefile.am: Remove. * Makefile.am: Merge-in start/Makefile.am. * configure.ac: Reflect changes above.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-2/+2
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-09-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-291-1/+0
| | | | | | | * Makefile.am: Merge-in include/Makefile.am. Reflect changes to bsp.am. * include/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-111-1/+1
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-111-1/+0
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-111-1/+1
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-281-2/+2
| | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * clock/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * console/Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * spurious/Makefile.am: Remove AUTOMAKE_OPTIONS. * start/Makefile.am: Remove AUTOMAKE_OPTIONS. * startup/Makefile.am: Remove AUTOMAKE_OPTIONS. * timer/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-031-7/+1
| | | | * configure.ac: Introduce RTEMS_BSP_CONFIGURE.
* 2001-11-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-11-151-0/+8
| | | | | * configure.ac: Add RTEMS_BSPOPTS_*(USE_CONSOLE_A), add RTEMS_BSPOPTS_*(USE_CONSOLE_B).
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-121-0/+36
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove.
