* configure.in: Remove.
* startup/linkcmds: Added lines so DWARF debug information
would be available. Otherwise gdb complains that the offsets
for the debug info are incorrect and doesn't load the files.
* clock/Makefile.am, console/Makefile.am, spurious/Makefile.am,
